Changes in velocity with Direction change
In summary, to find the change in velocity, you first need to understand that velocity is a vector. In this case, Tim's initial velocity is (0,6.4) and his final velocity is (5.8,0), representing his speed and direction. To find the change in velocity, you simply subtract the two vectors, resulting in a change of (5.8,-6.4). If the question asks for the magnitude of the change, you can find it by using the Pythagorean theorem, which in this case would give you 8.03m/s. However, if the question does not specify, you can leave the answer as the vector (5.8,-6.4), unless the question asks
skatergirl
Tim is running cross country at 6.4m/s when he completes a wide angle turn and continues at 5.8m/s[w]. What is his change in velocity?
Δv=v2-v1
a2+b2=c2
i am not sure how i am supposed to find the change in velocity...
i could just find the hypotenuse but i think that is giving me the resulting acceleration and not the actual change. but I am quite sure its not as simple as just subtracting the two values either ??
You have to remember that velocity is a vector: so we have [itex]v_1 = (0,6.4)[/itex] and [itex]v_2 = (5.8,0)[/itex] (where [itex](1,0)[/itex] points West and [itex](0,1)[/itex] points South), so as you correctly wrote: [itex]\Delta v = v_2 - v_1 = (5.8, -6.4)[/itex]. This is technically the change in his velocity, but the question may be just asking for its magnitude (which, as you note, is the hypotenuse).
ok i will include both in my answer then. thank you. also should i be including the angle/direction? do you draw the s or w arrow first when drawing the diagram? like will the angle be between the hyp and 5.8 or the hyp and 6.4?
If you include the information about what your axes are (i.e. South = (0,1), West = (1,0) ) then when you write the components of [itex]\Delta v[/itex] down you have represented it unambiguously. You shouldn't need to include it unless the question specifically asks you for it.
I'm not sure I understand the first question. In answer to the second, you would have to be specific (e.g. "the vector is 10° to the East of North", or "at a bearing of 010°" or some similar specification of angle - and note that was just an example, not the direction of [itex]\Delta v[/itex])
I would approach this problem by first understanding the concept of velocity and how it is affected by changes in direction. Velocity is a vector quantity, meaning it has both magnitude and direction. In this scenario, the initial velocity of Tim is 6.4m/s in the direction of South (represented by ). After completing a wide angle turn, his velocity changes to 5.8m/s in the direction of West (represented by [W]).
To find the change in velocity, we can use the equation Δv=v2-v1, where v2 is the final velocity and v1 is the initial velocity. In this case, v1=6.4m/s and v2=5.8m/s[W]. We can represent these velocities as vectors and use vector subtraction to find the change in velocity.
Using the Pythagorean theorem (a^2+b^2=c^2), we can find the magnitude of the change in velocity by taking the square root of the sum of the squares of the two components (South and West). This gives us a value of 0.9m/s.
Therefore, the change in velocity of Tim after completing the wide angle turn is 0.9m/s, with a direction of South-West. This represents a change in both magnitude and direction of his velocity.
FAQ: Changes in velocity with Direction change
How does changing direction affect an object's velocity?
Changing direction does not necessarily affect an object's velocity. Velocity is a vector quantity that includes both magnitude (speed) and direction. If the speed of an object remains constant, changing direction will not affect its velocity. However, if the speed changes while changing direction, then the velocity will also change.
What is the difference between velocity and speed?
Velocity and speed are often used interchangeably, but they have different definitions in physics. Speed is a scalar quantity that only measures the magnitude of an object's motion, while velocity is a vector quantity that includes both magnitude and direction. In other words, velocity tells us not only how fast an object is moving, but also in what direction.
How does an object's velocity change if it moves in a circular path?
If an object is moving in a circular path at a constant speed, its velocity is constantly changing. This is because velocity is a vector quantity and the object is constantly changing direction. However, the magnitude of the velocity (speed) remains the same, as long as the object maintains a constant circular path.
Can an object's velocity change if it moves in a straight line?
Yes, an object's velocity can change even if it is moving in a straight line. This can happen if the object speeds up or slows down, or if it changes direction. For example, if a car is driving at a constant speed of 50 mph and then suddenly turns left, its velocity has changed even though it is still moving in a straight line.
How do we calculate the change in velocity with direction change?
The change in velocity with direction change can be calculated using the formula: Δv = vf - vi, where Δv is the change in velocity, vf is the final velocity, and vi is the initial velocity. This formula takes into account both the magnitude and direction of the velocity and can be used to calculate the change in velocity for any type of motion.
