Changes in Work done with changes in the centre of mass of a tool
In summary, the question is asking whether changing the center of mass of a mop used to clean ceilings affects the level of difficulty in cleaning. It is unclear if the force referred to is the pushing or dragging motion, and the answer may depend on the specific scenario and the location of the weight along the mop's pole. Considering torque may provide more insight into this problem.
Mimi3616
If we change the centre of mass of a mop that is used to clean ceilings, is it easier to clean if centre of mass is away or closer to the point of application of force? In which situation force applied needs to be less, to do same work and in which case, applying the same force, will help us do more work? And how can we explain this with physics?
W = F*d
Work done if centre of mass is away from us will be less. But how? Or should we consider torque?
Hello @Mimi3616 , :welcome: !
Difficult to give a clear answer to a vague question (not intntionally vague, I suppose).
If this is homework: what is the exact wording of the problem statement ?
Your relevant equation is actually a vector equation: $$W =\vec F \cdot \vec d$$meaning that physically spoken, no work is done if the displacement in the direction of the force is zero.
Mopping means pushing up (in the ceiling case) and dragging sideways. The sideways motion is to overcome the friction. The upward force does no work: the vertical position of the mop does not change.
can you propose a scenario where you believe that is actually the case ?
Mimi3616 said:
Homework Statement:: If we change the centre of mass of a mop that is used to clean ceilings, is it easier to clean if centre of mass is away or closer to the point of application of force?
.. Or should we consider torque?
Depends what is meant by 'easier'. And it depends which 'force' you are referring to. Both are unclear.
Suppose you have a long pole, AB and you are holding end A. Which is easier to control: the pole with a heavy weight near end B or the pole with the heavy weight near end A? If that's what is meant by the question, then yes, you should consider torque.
Related to Changes in Work done with changes in the centre of mass of a tool
1. How does the centre of mass affect the work done with a tool?
The centre of mass of a tool plays a crucial role in determining the amount of work done. As the centre of mass shifts, the distribution of weight and force on the tool changes, which in turn affects the work done by the tool.
2. What factors can cause changes in the centre of mass of a tool?
Several factors can influence the centre of mass of a tool, such as the shape, size, and weight distribution of the tool, as well as any external forces acting on the tool.
3. How does the work done change when the centre of mass shifts towards the handle of the tool?
When the centre of mass moves towards the handle of the tool, the leverage and control over the tool increases, resulting in a decrease in the work done. This is because less force is required to achieve the same amount of work.
4. Can changes in the centre of mass affect the efficiency of a tool?
Yes, changes in the centre of mass can greatly impact the efficiency of a tool. If the centre of mass is not properly aligned with the direction of the force applied, it can result in wasted energy and decreased efficiency.
5. How can we optimize the centre of mass of a tool for maximum work output?
To optimize the centre of mass of a tool, we need to consider the design and weight distribution of the tool. By strategically placing the centre of mass closer to the point of application of force, we can increase the leverage and efficiency of the tool, resulting in maximum work output.
