Changing a tree into a list question
  • Thread starter transgalactic
  • Tags
    List Tree
In summary: }if (!root->right) { ...}if (root->value <= first) { //left childtree2list(root->left);}if (root->value <= last) { //right childtree2list(root->right);}}
transgalactic
1,395
i got a BST tree
each node builded like this:
Code:
typedef struct node node;
struct node {
  int value;
   node *left,* right,*next;
i need to change it into a sorted linked list from the smallest to the biggest.
i can't use malloc
and i can't change the anything in this tree
i need to write a function called
node *tree2list(node *root) that gets a root of the tree and returns the head of a list
first i can find the smallest member in this tree
Code:
while (tree->left){
tree=tree->left;
the problem comes when i need to find the second smallest
and put it to the "next" of the smallest member of all the tree
its a recursion
but i don't know how to make a pointer for a tree which will lack that "first found " node
because our pointer after that loop is at the bottom of a tree
i can't go back to the root
and i can't cut this "founded node" from that tree without changing the structure of a tree
Technology news on Phys.org
by "in order" traversal method
it goes from the smallest to the biggest
first it goes to the most left (the smallest) then it goes to the middle one
then to the biggest
so my solution is :
Code:
struct node {
  int value;
    if (root){
       return root;
by this traversal i go from the smallest to the biggest
BUT I DONT KNOW HOW TO DO THE LINKING PART
it should be some thing like
tree2list(root->left)->next=tree2list(root);
tree2list(root)->next=tree2list(root)->right;
but i don't know how to combine then in the recurstion
So first off, this:
Is *really bad*, it will cause an immediate infinite loop. There needs to be some kind of "termination condition" that will cause tree2list to NOT be called when you reach the leftmost place.
As for "how to combine them in the recursion", I am not altogether certain I understand what you are trying to do, but what I would recommend is that you add a second argument to tree2list pointing to the list you are trying to add to, and then you simply add nodes to the list pointed to as you go. (If that makes sense.)
Another option is to write some kind of separate "concatenate linked lists" function. If you have the ability to add one linked list to another, then your tree2list function becomes very simple, something like :
list l = tree2list(root->left)
list r = tree2list(root->right)
return list_concatenate(l, r)
this is an "in order " code
but i need that instead of printing the "value" of the node
it will link it to the "next" of the previous smaller node.
Code:
struct node {
  int value;
if (!root){
  return null;
    if (root){
       printf("%d",root->value);  //i need to change this line
the problem is i don't know how to define the recursive call
for the previous node in the list because it can be:
Code:
 return tree2list(root->left)->next=*root;
or
Code:
return tree2list(root->right)->next=*root;
I'm sorry, I just don't understand what it is you're trying to do here. I guess I can make two general comments about your particular code snippets here:
- You say "if (!root) return null;", then a few lines later you say "if (root) { do something }". The second if (root) is redundant because if root is null, then you have already returned from the function. Remember, if you "return" at any point during a function then the remainder of the function is not executed.
- If you say something->next=*root; this will not compile. "->next" and "root" are pointers to nodes, "*root" will be just a node. The types do not match.
- If you remove the asterisk and say " return tree2list(root->left)->next=root; " this will compile but I do not think it will do what you want. This will:
- Query tree2list to obtain a pointer to [some node]
- Assign the 'next' field of [some node] to root
- Throw the pointer to [some node] away and return root
Sometimes it is a good idea to try to only do one thing per line, so that you do not create confusions like this.
i tried to write a new function:
i got to the first stage of the base case.
when i put it into my tree
Code:
http://img204.imageshack.us/my.php?image=19509120rh8.gif
Code:
node tree2list(node *root,node *first,node *last)
if (!root->left) {
                  first=root;
                  first->next=last;
                  return last;
return last=tree2list(root->left,first,root);
in the end when i get to the call where
tree2list(node *root,node *first,node *last) root=node5 first=null last=node10
in this call
first=node5
first->next= node10
and it returns node10
i don't know how to continue
because
i kept only one variable (the last node)
i don't know how to keep the head of the list
and now i got only two nodes connected
i need to connect the last one (which is the local "father") to its right node
i don't know how to do this simple thing
and i can't think further regarding how it will act on the global scale
how to develop it further
Related to Changing a tree into a list question
1. Can a tree be converted into a list question?
Yes, a tree can be converted into a list question by breaking down the tree into its individual components and organizing them into a list format.
2. Why would someone want to change a tree into a list question?
Converting a tree into a list question can make it easier to analyze and understand the information contained within the tree. It also allows for a more concise and organized presentation of the information.
3. What is the process for changing a tree into a list question?
The process involves identifying the main branches and sub-branches of the tree, breaking them down into individual components, and then organizing them into a list format based on their relationships and connections.
4. Are there any tools or software that can assist with converting a tree into a list question?
Yes, there are various tools and software available that can aid in the conversion process. These include mind-mapping software, diagramming tools, and spreadsheet programs.
5. Can the conversion process result in any loss of information?
It is possible for some information to be lost during the conversion process, especially if the tree is complex and has many branches and sub-branches. However, with careful organization and attention to detail, the loss of information can be minimized.
