Changing from cartesian to polar
In summary, the problem asks to find the tangential and normal accelerations of a particle moving in a two-dimensional orbit, given its position and velocity equations. This can be done by using the equations for x''(t) and y''(t) and converting them to polar coordinates to find the tangential and normal components of acceleration.
CompStang
A particle moves in a two-dimensional orbit defined by:
x(t)= A(2[tex]\alpha[/tex]t-sin([tex]\alpha[/tex]t)
y(t)= A(1-cos([tex]\alpha[/tex]t)
a) Find the tangential acceleration a_t and normal acceleration a_n as a function of time where the tangential and normal components are taken with respect to the velocity.
x''(t)= A[tex]\alpha[/tex]^2sin([tex]\alpha[/tex]t)
y''(t)= A[tex]\alpha[/tex]^2cos([tex]\alpha[/tex]t)
I found both the velocity and acceleration for both x and y vectors given and realize that a(t)= x''(t)i[tex]\widehat{}[/tex]+ y''(t)j[tex]\widehat{}[/tex]
also I know that:
a(t)=a_nr[tex]\widehat{}[/tex]+a_t[tex]\phi[/tex][tex]\widehat{}[/tex]
So I need to find x" and y" in terms of polar to get the answe for a_n and a_t
sorry all these alphas are not supposed to be raised to the power of there previous components. it is supposed to be for example x(t)=A(2*(alpha)*t-sin((alpha)*t)...and so on
Changing from cartesian to polar coordinates can be helpful when dealing with circular or rotational motion, as seen in this problem. In order to find the tangential and normal accelerations, we can use the equations x''(t)= A\alpha^2sin(\alphat) and y''(t)= A\alpha^2cos(\alphat) in polar form. This means that instead of using the x and y components, we can use the radial and tangential components, which are r and \phi, respectively. By finding the derivatives of the polar equations, we can then plug them into the formula a(t)=a_nr\widehat{}+a_t\phi\widehat{} to find the tangential and normal accelerations as functions of time. This method can also be useful in other situations where the motion is more easily described in polar coordinates.
FAQ: Changing from cartesian to polar
What is the process of converting from cartesian to polar coordinates?
The process of converting from cartesian to polar coordinates involves using specific formulas and calculations to determine the equivalent polar coordinates for a given set of cartesian coordinates. This typically involves finding the distance from the origin (r) and the angle (θ) between the positive x-axis and the line connecting the point to the origin.
Why would someone want to change from cartesian to polar coordinates?
Converting from cartesian to polar coordinates can be useful in solving certain mathematical problems, particularly those that involve circular or symmetric shapes. It can also make it easier to graph and visualize certain equations and functions.
What are the main differences between cartesian and polar coordinates?
The main difference between cartesian and polar coordinates is the way in which points are represented. Cartesian coordinates use the x and y axes to plot points, while polar coordinates use a distance (r) and angle (θ) from the origin. Additionally, cartesian coordinates use a rectangular grid system, while polar coordinates use a circular grid system.
Can any point in cartesian coordinates be converted to polar coordinates?
Yes, any point in cartesian coordinates can be converted to polar coordinates, and vice versa. This is because both systems are based on the same underlying mathematical principles and can be converted using specific formulas and calculations.
Are there any real-world applications for converting from cartesian to polar coordinates?
Yes, there are many real-world applications for converting from cartesian to polar coordinates. For example, polar coordinates are commonly used in navigation, physics, and engineering to describe the position and movement of objects in relation to a fixed point.
