Changing magnetic field (magnetic mirror)
In summary, the magnetic field in cylindrical coordinates converges on the z-axis. The equation of motion for a particle in this field is given by: -m\frac{dv}{dt} = q(v \times B)where q is a constant of motion.
Kara386
208
I think this is a 'magnetic mirror' question - the field lines converge on the z axis.
For a particle moving into an area of increasing field strength, where the field lines converge. Assume the ##B## field is rotationally symmetric about the ##z## axis, with ##B = B_z \hat{z}## being the main field, ##B_r## pointing inwards and ##B_φ = 0## (cylindrical coordinates). Use the fact that this field has ##div B = 0## to find ##B_r##, and show that ##\frac{v_p^2}{B}## is a conserved quantity by considering the Lorentz force.
I'm a little rusty on cylindrical co-ords, but I think the field can be written as
##B = B_r \hat{r} + B_z \hat{z}##
In cylindrical co-ordinates the divergence of the field is (using the fact it's divergence free):
##\frac{1}{r}\frac{\partial{(r B_r)}}{\partial r} + \frac{\partial B_z}{\partial z} = 0##
With a converging field clearly ##B_z = B(z)##, and using the product rule on the first term:
##\frac{\partial B_r}{\partial r} + B_r + \frac{\partial B_z}{\partial z} = 0##
Which gives
##B_r = -\frac{\partial B_r}{\partial r} - \frac{\partial B_z}{\partial z}##
The equation of motion for this system is
##m\frac{dv}{dt} = q(v \times B) ##
Which can be calculated from the determinant
\left| \begin{array}{ccc}
\hat{r} & \hat{\theta} & \hat{z} \\
v_r & v_{\theta} & v_z \\
B_r & 0 & B_z\end{array} \right|##
##= qv_{\theta} B_z \hat{r} - \hat{\theta} q(vB_z - v_zB_r) - \hat{z} q v_{\theta} B_r##
Can't see how to show from there that the quantity ##\frac{v_p^2}{B}## is conserved. Not even sure that determinant is right! Thanks for any help! :)
First, your expression for ## B_r ## is incorrect. You dropped a factor of r. Since the change in the field with respect to r is much greater than the change in the field with respect to z you can show that ## B_r## is approximately proportional to r.
Secondly, look up the expressions for velocity in cylindrical coordinates and plug them into your determinant.
Third, for ##\frac{{v_p}^2}{B}## to be a conserved quantity it must be a constant of motion. That is, $$ \frac{d({\frac{{v_p}^2}{B}})}{dt}=0$$
Likes Kara386
Yes, I made lots of mistakes, I got there in the end though. Thanks anyway for your response! :)
Related to Changing magnetic field (magnetic mirror)
1. How does a magnetic mirror work?
A magnetic mirror is a device that uses a changing magnetic field to reflect charged particles, such as ions or electrons, in a specific direction. This is achieved by creating a magnetic field that gradually increases in strength towards the center of the mirror, causing the particles to bounce back and forth between the stronger and weaker fields. This confinement of particles can be used for various purposes, such as controlling plasma in fusion reactors.
2. What are the applications of a magnetic mirror?
Magnetic mirrors have various applications in both scientific research and practical technology. Some examples include particle accelerators, ion thrusters for spacecraft propulsion, magnetic confinement fusion devices, and particle detectors in experiments studying cosmic rays.
3. Can a magnetic mirror be used to trap particles permanently?
No, a magnetic mirror cannot trap particles permanently. The particles will eventually escape due to factors such as collisions with the walls of the mirror or energy losses. However, the confinement provided by a magnetic mirror can be sustained for extended periods of time and used for specific experiments or applications.
4. How does the strength of the magnetic field affect the behavior of particles in a magnetic mirror?
The strength of the magnetic field is a crucial factor in determining the behavior of particles in a magnetic mirror. A stronger magnetic field will result in a higher level of confinement, reducing the rate of particle loss. However, if the field is too strong, it can also cause particles to become trapped in the center of the mirror, preventing them from being reflected back and forth.
5. Are there any potential dangers associated with magnetic mirrors?
Magnetic mirrors can potentially be hazardous if not handled properly. The strong magnetic fields used can affect electronic equipment and may also pose a risk to individuals with pacemakers or other medical devices. It is important to follow proper safety protocols and procedures when working with magnetic mirrors.
