naeem shaik
- 7
In the below video it is shown that rpm is increasing by using external magnetic field . can i know on which principle it is based on?
Stargate means nothing to me; but if it has implications then I can see some people jumping to conclusions.meBigGuy said:He calls it a "stargate" effect and implies he is getting something for nothing.
He explains what the external magnets are doing on the video I viewed.He says nothing about weakening the effective stator magnets.
Many youtube videos demonstrate something without explaining principles behind it, probably to garner interest. It's often the case on youtube of here's a video I made, you go figure it out. The "Mythbusters" series took it upon themselves to confirm or debunk some of the more perplexing.If it actually explained what was going on and why, then I would agree.
NascentOxygen said:Stargate means nothing to me; but if it has implications then I can see some people jumping to conclusions.
The concept is based on the principle of electromagnetic induction, where an external magnetic field is used to induce a change in the speed of a motor. This is achieved by altering the strength and direction of the magnetic field, which in turn affects the motor's rotation.
One advantage is that it allows for precise control of motor speed, as the strength and direction of the magnetic field can be adjusted. It also eliminates the need for complex and bulky mechanical speed control systems, making it a more compact and efficient solution.
No, not all motors are compatible with this method. The motor must have a rotor that can be affected by an external magnetic field, such as a permanent magnet or a conductive rotor. This is typically found in brushless DC motors or induction motors.
One limitation is that the range of speed control may be limited, as it depends on the strength and direction of the external magnetic field. Also, the motor must be designed to handle the increased load caused by the magnetic field, as it may affect its overall performance and lifespan.
This method is commonly used in various industries, such as HVAC systems, electric vehicles, and robotics. It can also be used in household appliances, such as fans and blenders, for speed control.
