Changing Potential Energy of a Magnetic Coil
The discussion focuses on calculating the change in potential energy of a magnetic coil when rotated from an antiparallel to a parallel orientation with a magnetic field. The magnetic moment of the coil is given as 1.40 Am^2 and the magnetic field strength is 0.830 T. The initial potential energy is calculated using the formula U = -uBcos(phi), resulting in a value of -1.162 J for the initial state and 1.162 J for the final state. The change in potential energy is ultimately determined to be -2.324 J, correcting earlier confusion regarding angle interpretations. The final conclusion emphasizes the importance of accurately applying trigonometric functions in potential energy calculations.
clope023
A coil with magnetic moment 1.40 Am^2 is oriented initially with its magnetic moment antiparallel to a uniform magnetic field of magnitude 0.830 T.
What is the change in potential energy of the coil when it is rotated 180 degrees, so that its magnetic moment is parallel to the field?
u = IA = magnetic moment
U = -uBcos(phi)
U1 = -uBcos(180) = -1.162J
U2 = -uBcos(360) = 1.162J
deltaU = U2-U1 = 1.162J - (-1.162J) = 2.324J
just wondering if I did the problem correctly, I'm not sure I have the correct angles; any help is greatly appreciated.
It's just \Delta U = \mu B since U=-\mu B cos(\phi)=-\mu B cos(180) =-\mu B*(-1)=\mu B
I actually tried that before and it came out incorrect.
edit: which is strange since reviewing my concepts again showed that the antiparallel (perpendicular) potential energy should have been 0 so more than likely it should have turned out like you said.
would it be possible that the trig function as changed?
it turns out I was correct (according to masteringphysics in this case the first antiparallel angle was 180 degrees) but the sign was negative, turns out it was like this:
U = Uf-Ui
= (-1.4*.830*cos(360))-(-1.4*.830*cos(180)) = -2.324J
thanks for the help anyway dude.
