Changing Rho, Finding Resistance
  • Thread starter Bluestribute
  • Tags
    Resistance
In summary, changing the value of Rho can significantly impact the resistance of a material. Resistance is calculated by dividing the voltage by the current, and Rho is a constant that represents the material's resistance per unit length and cross-sectional area. By increasing or decreasing Rho, the overall resistance of the material can be altered, making it a crucial factor in designing and engineering various electrical systems. Additionally, finding the right balance between Rho and other material properties is essential for achieving optimal performance and efficiency in electronic devices.
Bluestribute
194
A wire with cross-sectional radius 0.91 mm lying along the x-axis from x=0 to x=0[PLAIN]http://loncapa.mines.edu/adm/jsMath/fonts/cmmi10/alpha/100/char3A.png90 m is made of an alloy that varies with its length in such a way that the resistivity is given by [PLAIN]http://loncapa.mines.edu/adm/jsMath/fonts/cmmi10/alpha/100/char1A.png=6x^1 [PLAIN]http://loncapa.mines.edu/adm/jsMath/fonts/cmr10/alpha/100/char0A.png[PLAIN]http://loncapa.mines.edu/adm/jsMath/fonts/cmsy10/alpha/100/char01.png m, for x in meters. What is the resistance of this wire?
dR=(rho)dL/A
(I can't find the symbol window so bare with my explanation). Resistance is the integral of rho times length, divided by cross sectional area. I figured since L and A are constants, I could pull them out and simply do: rho, integrated from 0 to 0.9, times L/A, with everything converted to meters. Didn't work.
Then I tried not integrated and just plugging and chugging. Didn't work.
Then I came here.
dR=(rho)dL/A
What didn't work? Please show what you got and how you got it.
Also, is there a typo in ##\rho##? It seems odd to me that it would be 6x1 ohms/m. I don't know why anyone would write x1 instead of just x.
Then I came here.
So I'm on my phone, but I integrated the rho function and multipled by L/A, L being the difference in the bounds and A being the given mm amount (converted to meters).
It's to the first power cause the numbers are random, including the exponents
The notation rho*dL/A doesn't mean integrate rho and then multiply by L/A. It means integrate rho WITH RESPECT to L and then divide by A. By all means, show your work. I think you are multiplying by an extra factor L. Check the units. Remember dL has units of m. Are they ohms or something else?
##\int dR = \int_a^b \frac{\rho}{A} dL \implies R=\frac1A\int_a^b \rho dL## You should not have to multiply by length, it is included in the integral.
Ok, I'm back and found out where I was going wrong. Also, the parameters change each time, so don't freak out with me inputting new numbers in my explanation.
So yes, I don't know why I was multiplying by length afterwards . . . Good to catch it now though. Anyways, I integrated the resistivity across the bounds: the integral of 4x from 0 to 0.5. Then I divided by the AREA of the given radius. That's where I was going wrong multiple times. They gave me a radius of 0.46 MM. For some reason I was using this as "A" instead of solving for A . . . So in short, integrated my resistivity function across my wire length and divided by the cross sectional area.
Got it instantly when I started writing out my variables here and realized it was radius, not area . . .
FAQ: Changing Rho, Finding Resistance
1. How does changing the Rho affect resistance?
Changing the Rho, or resistivity, of a material directly affects its resistance. The higher the resistivity, the higher the resistance, and vice versa.
2. What factors can cause changes in Rho?
Rho can be affected by factors such as temperature, the type of material, and the amount of impurities present. In general, materials with higher resistivity will have a higher Rho.
3. Can changing the length or thickness of a material affect its Rho and resistance?
Yes, changing the length or thickness of a material can change its Rho and resistance. In general, longer and thinner materials will have a higher Rho and resistance compared to shorter and thicker materials.
4. What is the relationship between Rho and conductivity?
Rho and conductivity have an inverse relationship. This means that materials with higher resistivity (higher Rho) will have lower conductivity, and materials with lower resistivity (lower Rho) will have higher conductivity.
5. How does changing the cross-sectional area of a material affect its Rho and resistance?
Changing the cross-sectional area of a material does not directly affect its Rho. However, it can affect the resistance of the material as resistance is directly proportional to length and inversely proportional to cross-sectional area.
