I Changing the RPM of a frictionless spinning wheel in a box
A frictionless spinning wheel in a vacuum box will continue to rotate at its initial RPM, as external movements of the box do not affect the wheel's rotation due to the conservation of angular momentum. The wheel's RPM remains unchanged as long as there is no friction or external forces acting on it. The discussion highlights that turning the handlebars of a bike while the front wheel is spinning does not alter the wheel's RPM in an ideal frictionless scenario. It is emphasized that the wheel must be perfectly balanced and rigid for this principle to hold true. Overall, the conservation of angular momentum is key to understanding the behavior of the spinning wheel.
SpaceThoughts
Imagine a spinning wheel built into a hand size vacuum box. There is no friction between the axe bearings of the wheel and the box. Let's say that the wheel rotates with 60 RPM. Am I right if I assume:
1. The wheel continues to rotate, approximately as if in space.
2. It is not possible to change the 60 RPM in any way, as long as the box and the content is not broken. No matter how we twist and turn the box from the outside.
How is the wheel axle attached to the interior of the box? How does gravity play in all of this?
Also, you can certainly design things to be able to add rotational energy to the spinning wheel, such as using a rotor from an electric motor as your spinning wheel...
Let me ask the same question in a less confusing way:
I lift the front wheel of my bike off the ground and make it spin. I turn the handlebars right-left-right-left.
I feel the resistance of moving the handlebar back and forth. The faster the wheel spins the more resistance.
Will turning the handlebar back and forth change the RPM of the bike wheel, or would the wheel continue to rotate with the same RPM if there were no friction?
From my experience I think the RPM would not change, but I have not found a clear answer to this question.
For the ideal case with no axial friction and, say, a perfectly rigid wheel your experience is correct. To see this you could perhaps ask yourself what mechanical quantity usually is conserved in cases of no friction and see if this helps you conclude something. This will also explain why the wheel, in addition to the axis bearings, has to be idealized (i.e. have no internal friction).
One needs the assumption that the wheel is balanced.
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
