Changing the Seasons by Shifting Center of Mass
In summary, the conversation discusses how to create seasons within a Dyson Sphere by adjusting the position of the Sun. The group initially struggled with interpreting the problem, but eventually used the spherical shell theorem to determine that there would be no net gravitational force between the Sun and the sphere. They then used the previously calculated angular velocity to determine the length of a year, with the understanding that the Sun would need to be placed at a specific location to create seasons.
Seth Newman
On Earth, seasons occur due to the tilt of our planet. In the SSDS (A Dyson Sphere built around our sun), we can cause seasons to occur by having the Dyson sphere be not perfectly centered around the sun. If you want the sun to be 10% closer to the one side of the Dyson sphere in “Summer” and 10% further than average in “Winter”, what will be the length of a “year”?
None given, but we are all pretty familiar with angular kinematics, gravitation, and most other ideas in introductory physics.
This is a group challenge problem for the last section of intro calc-physics. We are having trouble deciding how to interpret the problem. First, we tried to solve the problem using properties of angular velocity, but it didn't end up making a whole lot of sense. We then made the assumption that the Dyson sphere is similar to the earth-sun system, so we adjusted "R" to be +/- 10% and solved for the period. We got an answer (366.8 days) but conceptually this makes no sense.
Any thoughts/ideas or bumps in the right direction would be greatly appreciated. Thanks!
I'm not sure what you did here. What do you mean by "adjusted 'R'"--the radius of the Dyson sphere? Are you referring to two different orbits or an eccentric orbit? (By Kepler's laws, how does the period vary with eccentricity?)
If the Dyson sphere (a shell, really) is of uniform density and perfectly symmetric, then what's its gravitational influence on anything inside it? And by symmetry, what's the gravitational influence of anything inside it (a Sun, perhaps) on the Dyson sphere?
Ah--true. (And obvious.)
Okay. So if we use the spherical shell theorem, then no net gravitational force on the inside has a net gravitational force on anything outside. So the forces are equal and opposite? Does this mean the sun exerts no net force on the Dyson sphere?
Yes. As I should have remembered. (For a Niven ring, if you've come across that, it's worse--the situation is unstable and the ring will fall towards the star.)
Likes Seth Newman
That's not what the shell theorem states. You might want to review it.
Right. There will be no net force between the Sun and shell (or between the shell and anything else inside the shell). What can you do with this information?
Likes Seth Newman
Ahh. Okay. In a previous problem we calculated the angular velocity needed in order to simulate Earth's gravity within the Dyson sphere (there's supposedly people living inside the sphere) so we should be able to use the angular velocity to calculate the period of one rotation (which is the length of a year)?
Sure.
If the Sun is at the exact center then there would be nothing to distinguish seasons anywhere on the inside surface since the distance would be always the same everywhere. I suppose your job is to place the Sun at a location that allows for seasons as desired. Your rotation rate depends on other factors as you've already determined.
Likes Seth Newman
gneill said:
Sure.
Great, thanks a bunch. We were stuck in a conceptual hell trying to solve this. I feel bad that it was so obvious. Appreciate it!
Related to Changing the Seasons by Shifting Center of Mass
What is "Changing the Seasons by Shifting Center of Mass"?
"Changing the Seasons by Shifting Center of Mass" is a scientific concept that proposes that the Earth's seasons can be altered by shifting the position of the Earth's center of mass.
How does shifting the center of mass affect the Earth's seasons?
Shifting the Earth's center of mass can affect the Earth's seasons by changing the tilt of its axis. This tilt determines the amount of sunlight that reaches different parts of the Earth, causing the change in seasons.
Is there evidence to support this concept?
While there is currently no scientific evidence to support this concept, some scientists have proposed that changes in the Earth's rotation and orbit could potentially alter the Earth's center of mass and therefore impact the seasons.
Can we intentionally shift the Earth's center of mass to control the seasons?
At this time, there is no known way to intentionally shift the Earth's center of mass. Even if we could, it is uncertain whether it would have a significant enough effect on the Earth's seasons to be noticeable.
What are the potential implications of this concept?
If this concept were proven to be true, it could have significant implications for our understanding of the Earth's climate and could potentially lead to new methods of controlling or predicting seasonal changes.
