Characteristic Impedance differences
In summary, characteristic impedance is a measure of the opposition to current flow in an electrical circuit and takes into account both resistance and reactance. Differences in characteristic impedance can lead to reflections and signal distortion, especially at high frequencies. To minimize these effects, it is important to match the characteristic impedance of components in a circuit. This can be achieved through various methods such as using impedance matching circuits, transmission line transformers, and components with specific characteristic impedance values. The characteristic impedance of a circuit can also be affected by factors such as material, geometry, frequency, and environmental conditions.
quicksilver123
173
TL;DR Summary
Coax vs open wire feed
Could I get a conceptual answer, supported by math, explaining why coax has less characteristic impedance than open wire feeds?I’m new to EE. Thanks for you patience.
The line impedance is proportional to √( L / C ) where L and C are the inductance and capacitance per unit length.
Open wire line separated by air, has higher inductance and lower capacitance than coaxial cable separated by a dielectric.
Likes berkeman and tech99
Related to Characteristic Impedance differences
What is characteristic impedance?
Characteristic impedance is a measure of the resistance and reactance of a transmission line or medium. It is the ratio of voltage to current in a wave that is propagating through the line or medium.
Why is characteristic impedance important?
Characteristic impedance is important because it determines the efficiency of signal transmission in a given medium. It also helps to match the impedance of the source and load in order to minimize signal reflections and maximize power transfer.
What is the difference between characteristic impedance and characteristic impedance differences?
Characteristic impedance refers to the overall impedance of a transmission line or medium, while characteristic impedance differences refer to variations in impedance along the length of the line. These differences can cause signal reflections and distortions, which can affect the overall performance of the transmission line.
What causes characteristic impedance differences?
Characteristic impedance differences can be caused by changes in the physical properties of the transmission line, such as variations in its width or thickness, or by the presence of impedance-disrupting components like connectors or splices. These differences can also be caused by impedance mismatches between different sections of the transmission line.
How can characteristic impedance differences be minimized?
Characteristic impedance differences can be minimized by using high-quality transmission lines with consistent physical properties, and by properly matching the impedance of the source and load. Additionally, using impedance-matching components like baluns and transformers can help to reduce reflections and distortions caused by characteristic impedance differences.
  • Electrical Engineering
