MHB Characterization of External Direct Sum - Cooperstein, pages 359 - 360
  • Thread starter Thread starter Math Amateur
    Direct sum Sum
Math Amateur
MHB
I am reading Bruce N. Coopersteins book: Advanced Linear Algebra (Second Edition) ... ...
In Section 10.2 Cooperstein writes the following, essentially about external direct sums ... ...
Cooperstein asserts that properties (a) and (b) above "characterize the space $$V$$ as the direct sum of the spaces $$V_1, \ ... \ ... \ , V_n$$."
Can someone please explain how/why properties (a) and (b) above characterize the space $$V$$ as the direct sum of the spaces $$V_1, \ ... \ ... \ , V_n$$?Help will be appreciated ...
Peter
Let's investigate just two factors (extending this to arbitrarily finitely many isn't hard, but it takes more dots and more "index hell").
We want to show that given $V$, and two other vectors spaces $V_1,V_2$ along with four LINEAR maps:
$\pi_1:V \to V_1$
$\pi_2:V \to V_2$
$\epsilon_1:V_1 \to V$
$\epsilon_2:V_2 \to V$
such that:
$\pi_1\circ\epsilon_1 = 1_{V_1}$
$\pi_2\circ\epsilon_2 = 1_{V_2}$
and:
$\epsilon_1\circ \pi_1 + \epsilon_2\circ\pi_2 = 1_V$
that $V \cong V_1 \oplus V_2$.
So, one way we can do this is to exhibit an isomorphism:
$\phi: V \to V_1 \oplus V_2$ (Note I haven't said anything about whether or not the $V_i$ are even subspaces of $V$).
So here is how we will define $\phi$:
$\phi(v) = (\pi_1(v),\pi_2(v))$. Note this has the proper co-domain.
First, we'll show that $\phi$ is linear:
$\phi(v+v') = (\pi_1(v+v'),\pi_2(v+v')) = (\pi_1(v) + \pi_1(v'),\pi_2(v) + \pi_2(v'))$
$= (\pi_1(v),\pi_2(v)) + (\pi_1(v'),\pi_2(v')) = \phi(v) + \phi(v')$.
$\phi(av) = (\pi_1(av),\pi_2(av)) = (a\pi_1(v),a\pi_2(v)) = a(\pi_1(v),\pi_2(v)) = a\phi(v)$.
Now suppose that $\phi(v) = (0,0)$. We want to show $v = 0$.
Now $\phi(v) = (\pi_1(v),\pi_2(v))$, so if $\phi(v) = (0,0)$, we have (for this $v$):
$\pi_1(v) = 0$
$\pi_2(v) = 0$.
Since the $\epsilon_i$ are linear, we have: $\epsilon_1(0) = 0$, and $\epsilon_2(0) = 0$.
Thus $v = 1_V(v) = (\epsilon_1\circ \pi_1 + \epsilon_2\circ\pi_2)(v) = (\epsilon_1\circ \pi_1)(v) + (\epsilon_2\circ\pi_2)(v)$
$= \epsilon_1(\pi_1(v)) + \epsilon_2(\pi_2(v)) = \epsilon_1(0) + \epsilon_2(0) = 0 + 0 = 0$.
Thus $\phi$ is injective.
Before we tackle surjectivity, we prove a preliminary result:
$\pi_1 \circ \epsilon_2 = 0$
$\pi_2 \circ \epsilon_1 = 0$.
To prove this, we note that the $\pi_i$ are surjective, I will show this for $\pi_1$ (the proof is just the same for $\pi_2$):
Let $v_1 \in V_1$. Then we have $\pi_1(\epsilon_1(v_1)) = v_1$, so $v_1$ has the pre-image under $\pi_1$ of $\epsilon_1(v_1) \in V$.
Now for any $v \in V$, we have:
$v = \epsilon_1(\pi_1(v)) + \epsilon_2(\pi_2(v))$, so taking $\pi_2$ of both sides, we have:
$\pi_2(v) = \pi_2(\epsilon_1(\pi_1(v)) + \epsilon_2(\pi_2(v))) = \pi_2(\epsilon_1(\pi_1(v))) + \pi_2(\epsilon_2(\pi_2(v)))$
$= \pi_2(\epsilon_1(\pi_1(v))) + \pi_2(v)$.
Subtracting $\pi_2(v)$ from both sides, we have:
$0 = \pi_2(\epsilon_1(\pi_1(v)))$.
Now since $\pi_1$ is surjective, we can write ANY $v_1 \in V_1$ as $\pi_1(v)$ for SOME $v \in V$, so the above shows that (for such a $v$ so that $v_1 = \pi(v)$):
$0 = \pi_2(\epsilon_1(v_1))$, and thus this holds for any $v_1 \in V_1$.
The other condition is proved similarly.
Finally, let $(v_1,v_2)$ be any element of $V_1 \oplus V_2$.
Consider $\epsilon_1(v_1) + \epsilon_2(v_2) \in V$.
We have $\phi(\epsilon_1(v_1) + \epsilon_2(v_2)) = \phi(\epsilon_1(v_1)) + \phi(\epsilon_2(v_2))$
$= (\pi_1(\epsilon_1(v_1)),\pi_2(\epsilon_1(v_1))) + (\pi_1(\epsilon_2(v_2)),\pi_2(\epsilon_2(v_2)))$
$= (v_1,0) + (0,v_2) = (v_1,v_2)$, and $\phi$ is surjective.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
