Charge and Energy for Capacitors in Different Configurations
In summary, to fully charge a 0.15 uF and a 0.20 uF capacitor in parallel, a 12V battery must expend 2.52 x 10^-5 J of energy and allow 4.20 μC of charge to flow through it. In series, the battery must expend 6.17 x 10^-6 J of energy and allow 1.03 μC of charge to flow through it. These calculations were based on the equations C(eq) = ((1/C1)+(1/C2)+...+(1/Cn))^-1 and C(eq) = C1+C2+...+Cn for equivalent capacitance, U = 0.5CV^2
rowkem
51
How much energy must a 12V battery expend to fully charge a 0.15 uF and a 0.20 uF capacitor when they are (a) in parallel and (b) in series? How much charge flowed through the battery in each case?
i: C(eq)=((1/C1)+(1/C2)+...+(1/Cn))^-1 and C(eq)=C1+C2+...+Cn
ii: U=0.5CV^2
iii: Q=CV
I have worked it out but, I prefer not to post my answers. However, I did the following for (a) and (b):
1) Worked out the equivalent capacitance of each circuit using the appropriate equation (i)
2) Used the result(s) of part 1 and plugged that into equation (ii) using the voltage of the battery to get U for each circuit (energy expended by the battery solved)
3) Used the result(s) from part 1 and the given battery voltage in equation (iii) to obtain the charge for each circuit. (charge through battery solved)
So - that's essentially what I did. Was I correct in my methods? Thanks.
The OP's methods are correct.
Given: ##C_1 = 0.15~μF~~~;~~~C_2 = 0.20~μF~~~;~~~U = 12~V##
##C_p = C_1 + C_2 = 0.35~μF##
##C_s = \frac{C_1 C_2}{C_1 + C_2} = 85.7~nF~~(8.57~×~10^-8~F)##
Then the energy expended by the battery in each case is:
##E_p = ½ C_p U^2 = 2.52~×~10^{-5}~J##
##E_s = ½ C_s U^2 = 6.17~×~10^{-6}~J##
and the charge moved in each case:
##Q_p = C_p U = 4.20~μC##
##Q_s = C_s U = 1.03~μC##
FAQ: Charge and Energy for Capacitors in Different Configurations
How is the charge on a capacitor affected by its configuration?
The charge on a capacitor is directly proportional to the voltage across it, but is also influenced by its configuration. In series capacitors, the charge on each capacitor is the same, while in parallel capacitors, the total charge is divided among the individual capacitors.
How does the energy stored in a capacitor differ in different configurations?
The energy stored in a capacitor is proportional to the square of its voltage and is also influenced by its configuration. In series capacitors, the total energy stored is equal to the sum of the energy stored in each capacitor, while in parallel capacitors, the total energy stored is equal to the energy stored in each individual capacitor.
How does the capacitance of a capacitor change in different configurations?
The capacitance of a capacitor is affected by its configuration. In series capacitors, the total capacitance is equal to the reciprocal of the sum of the reciprocals of the individual capacitances. In parallel capacitors, the total capacitance is equal to the sum of the individual capacitances.
Can the charge and energy of a capacitor be changed by altering its configuration?
Yes, the charge and energy of a capacitor can be changed by altering its configuration. By connecting capacitors in series or parallel, the overall charge and energy stored in the capacitor can be modified.
How does the voltage affect the charge and energy of a capacitor in different configurations?
The voltage directly affects the charge and energy of a capacitor in different configurations. The higher the voltage, the more charge and energy the capacitor can hold. In series capacitors, the voltage is divided among the individual capacitors, while in parallel capacitors, each capacitor has the same voltage across it.
