Idoubt
- 172
- 1
If you place a charge +q at the exact center of a conducting sphere, will it stay there or move to the surface?
Idoubt said:If you place a charge +q at the exact center of a conducting sphere, will it stay there or move to the surface?
henry_m said:Here's an interesting question inspired by discord's post: suppose we have a positively charged particle and a positively charged conducting sphere. We hold the charge a little off centre and let all the charges in the sphere settle down (so it's just electrostatics), and then let it go. Does the charge move back to the centre or go off and hit the sphere?
If the sphere is uncharged, I think it's fairly clear that it will be the latter. After a little thought I'm convinced that if the charge on the sphere is high enough, it will be the former. But at what ratio does the behaviour change?
It will spread out and distribute itself evenly across the surface regardless of the charge already there. It will not be in any kind of equilibrium in the center.Idoubt said:If you place a charge +q at the exact center of a conducting sphere, will it stay there or move to the surface?
The charge at the center of a conducting sphere is always zero. This is because in a conducting material, charges are free to move, so any excess charge will always distribute itself evenly on the surface of the sphere.
The charge on a conducting sphere will always move to the surface and distribute itself evenly when exposed to an external electric field. This is known as electrostatic shielding and ensures that the electric field inside the conducting sphere is always zero.
No, the size of the conducting sphere does not affect the charge at the center. As mentioned before, the excess charge will always distribute itself evenly on the surface of the sphere, regardless of its size.
No, the charge at the center of a conducting sphere cannot be changed. Any excess charge will always distribute itself evenly on the surface of the sphere and the charge at the center will remain zero.
The charge at the center of a conducting sphere has no effect on the electric potential inside the sphere. This is because the electric field inside a conducting material is always zero, and the electric potential is directly related to the electric field.
