Charge collection principles for gaseous detectors
In summary, the difference in charge collection for gaseous detectors is determined by the type of detector and mode of operation. Ion chambers collect both electrons and positive ions, proportional counters primarily measure the drift of positive ions, and GM tubes can measure the total current but the specific value is not important. It is possible to separate the current from electrons and positive ions with a careful choice of capacitances.
abotiz
72
Hi,
I am reading the great Knoll book about radiation detection and measurement, and I don't fully understand the difference in charge collection for gaseous detectors. Is it the collection of electrons or positive ions in the detectors, a) Ion chamber, b) Proportional counters, c) GM tubes
This is what I do know,
1) When charged particles are subjected to an electric field, they move to the respective electrodes. This motion constitutes to a current which you measure. Electrons move faster then ions, however, positive ions motion contributes to a higher current (due to their mass?)
This is what I think is true,
2) Ion chambers, in current mode you collect both (electrons and positive ions) because the production of ion pairs reaches an equilibrium. In pulse mode you want to approximate the current measured to the energy depostited, so you want a fast counting system, therefore you only measure the current from the electrons.
3) In Proportional counters, almost all charge carriers (positive ions and electrons) are created near the anode, and the largest contribution to the puls is the drift of the positive ions due to their larger mass??
4) In GM tubes, Iam not sure, do you measure the total current created from both electrons and positive ions from the entire tube?
Another question I have is, how do you ONLY measure the current from positive ions and not electrons, vice versa ? Current, viewed from Ohms law does not separate electrons and positive ions. When Knoll says e.g. the signal measured is mostly due to the drift of the positive ions, is this because the integration time of the circuit is chosen in such way which makes the statement true?
Thank you very much!
The amount of charge from the initial track is the same for both, as the initial gas is neutral. I would not expect a different current, unless you use charge amplification at the electrodes (but then it depends on the geometry).
The anode gets significant current peaks when the electrons hit it.
You can measure the total current, but the precise value does not matter anyway.
With a careful choice of capacitances, you can separate them.
Likes 1 person
Related to Charge collection principles for gaseous detectors
1. What is the basic principle of charge collection in gaseous detectors?
The basic principle of charge collection in gaseous detectors is the creation and collection of ionization charges produced by the interaction of particles with the gas medium. These charges are then amplified and converted into electrical signals that can be measured and analyzed.
2. How does the electric field in a gaseous detector affect charge collection?
The electric field in a gaseous detector is crucial for the efficient collection of ionization charges. It accelerates the charges towards the collection electrodes and ensures their proper trajectory and timing for accurate measurement.
3. What is the role of gas amplification in charge collection for gaseous detectors?
Gas amplification, also known as gas multiplication, is a key step in charge collection for gaseous detectors. It involves the creation of a cascade of secondary electrons through gas ionization, resulting in a significant increase in the number of charges available for collection.
4. How do different gas mixtures and pressures affect charge collection in gaseous detectors?
The choice of gas mixture and pressure in a gaseous detector can significantly impact the efficiency of charge collection. Different gases have varying ionization potentials and electron drift velocities, which can affect the number of charges produced and their collection. The gas pressure also plays a role in determining the electric field strength and the distance between the ionization and collection regions.
5. Can environmental factors affect charge collection in gaseous detectors?
Yes, environmental factors such as temperature and humidity can impact the performance of gaseous detectors. Changes in temperature can affect the gas properties and the electric field strength, while high humidity can cause unwanted electric discharges that can interfere with charge collection.
  • Electromagnetism
  • Nuclear Engineering
  • Electromagnetism
  • Electrical Engineering
  • Electromagnetism
