Charge density from electric flux density
In summary, the charge density due to the given electric flux density is \rho _{v} = 4sin(\phi) + 4z.
freezer
76
Determine the charge density due to the following electric flux density:
[tex]\overrightarrow{D} = \hat{r}4rsin(\phi ) + \hat{\phi}2rcos(\phi)+\hat{z}2z^{2}[/tex]
[tex]\rho _{v} = \triangledown \cdot \vec{D}[/tex]
[tex]\rho _{v} = \frac{\partial }{\partial r} + \frac{\partial }{\partial \phi}+ \frac{\partial }{\partial z}[/tex]
[tex]\rho _{v} = \frac{\partial }{\partial r} 4rsin(\phi) + \frac{1}{r}\frac{\partial }{\partial \phi}2rcos(\phi)+ \frac{\partial }{\partial z}2z^{2}[/tex]
[tex]\rho _{v} = 4sin(\phi)- 2sin(\phi) + 4z[/tex]
[tex]\rho _{v} = 2sin(\phi) + 4z[/tex]
does this look correct?
There is a term missing here.
I am not seeing it. For cylindrical I am only seeing the 1/r on the phihat term
Stick a term 4sinø in there somewhere, anywhere. No partial derivative. Just that term. (It's part of the rhat coefficient: 4rsinø/r).
I would say that your solution looks correct. However, it would be helpful to provide some context or explanation for your calculations and how you arrived at your answer. Additionally, you may want to check your units to make sure they are consistent with the given units for electric flux density and charge density.
Related to Charge density from electric flux density
What is charge density from electric flux density?
Charge density from electric flux density is a concept in electromagnetism that describes the amount of electric charge per unit volume in a given region of space, as determined by the electric flux density. It is a measure of the concentration of electric charge in a particular area.
How is charge density related to electric flux density?
Charge density and electric flux density are closely related, as charge density is calculated by dividing the electric flux density by the permittivity of the medium in which the charges are present. In other words, it is a way of measuring the amount of electric flux per unit volume.
What are some common units of charge density?
The SI unit of charge density is coulombs per cubic meter (C/m^3), but it can also be expressed in other units such as coulombs per liter (C/L) or coulombs per cubic centimeter (C/cm^3). In some cases, charge density may also be measured in units of charge per unit area, such as coulombs per square meter (C/m^2).
How is charge density calculated?
Charge density is typically calculated by dividing the electric flux density by the permittivity of the medium in which the charges are present. In mathematical terms, it can be expressed as ρ = D/ε, where ρ represents the charge density, D is the electric flux density, and ε is the permittivity of the medium.
What is the significance of charge density in electromagnetism?
Charge density plays a crucial role in understanding and predicting the behavior of electric fields and currents in a given region of space. It is an important concept in electromagnetism that helps scientists and engineers to design and analyze various electrical systems and devices, such as capacitors, inductors, and transmission lines.
  • Differential Geometry
