Charge density higher on sharp ends
In summary: The ratio of the electric fields at the surfaces will then be in terms of the ratio of the radii. This can be used to explain why the charge density is higher on the sharp and pointed ends of a conductor compared to its flatter portions. In summary, two charged conducting spheres of radii a and b are connected by a wire and have the same potential on their surfaces. The ratio of the electric fields at their surfaces can be found by using the ratio of their radii and this can be used to explain why charge density is higher on the sharp and pointed ends of a conductor compared to its flatter portions.
Quantumkid
Two charged conducting spheres of radii a and b are connected to
each other by a wire. What is the ratio of electric fields at the surfaces
of the two spheres? Use the result obtained to explain why charge
density on the sharp and pointed ends of a conductor is higher
than on its flatter portions.
first part can be done by using the fact that electric field outside the sphere is given by E = q / 4(pi)(e_0)r^2
some confusion at second one
You don't know the charge on each sphere, so E = q / (4(π)(ε0)r2) will not get you anywhere until you do know those relative charge values. (Also, parentheses are important.)
The spheres are connected by a wire so their surfaces are at the same potential. Use that to find the relative charge on the spheres.
Related to Charge density higher on sharp ends
1. What is charge density?
Charge density refers to the amount of charge per unit volume in a material or object. It is typically measured in coulombs per cubic meter (C/m3).
2. Why is charge density higher on sharp ends?
This is because sharp ends have a smaller surface area compared to their volume. This means that the charge is concentrated in a smaller space, resulting in a higher charge density.
3. How does charge density affect electric fields?
A higher charge density results in a stronger electric field. This is because the electric field is directly proportional to the charge density.
4. What are some examples of objects with high charge density on sharp ends?
Some examples include lightning rods, needles, and fine-tipped electrodes used in scientific experiments.
5. How is charge density related to the concept of electric potential?
The electric potential is the amount of energy per unit charge in an electric field. In the case of sharp ends with higher charge density, the electric potential is also higher due to the stronger electric field.
