Charge density of a infinite straight wire
In summary, the conversation is discussing a question about a physics problem involving a proton being shot at an infinite straight wire with a charge density. The goal is to determine the nearest distance of approach, and the conversation includes a discussion about the necessary equations and missing details in order to solve the problem accurately. The conversation also mentions the importance of understanding how electric potential or electric field varies with distance from an infinitely long line charge.
caheobong
Hi, I am new to this forum. I have a question on one of the physics problem.
a proton is shot with a speed v from the point a in the vicinity of a infinite straight wire carrying a charge density. in term of these variables determine the nearest distance of approach.
Ki+Ui=Kf +Uf
Ui=0, Kf=0
U= (K*q1*q2)/d
so this is what I have done so far:
first I set Ki+Ui=Kf+Uf
since Ui=0, Kf=0 then
Ki=Uf
Ki= (1/2)*m*(v^2) ( m is mass of proton)
Uf= (k*q1*q2)/d ( d is the distance we looking for, q1=e proton, q2= charge density *L)
set Uf=Ki and solve for d
d= (e * charge density * L)/ ( mass of proton * (V^2) * 2 * pi * Eo)
This is my attempt how to solve this problem. however this is an infinite charge wire, the result should not depend on L the length of the wire. So please help me. any hints will help.Thank you so much.
It looks like some important details are missing:
Is the proton shot directly at the line charge? (Then the line charge must be positive for the question to make sense.)
If so, is its path perpendicular to the line charge?
If not, then there are details missing regarding the direction of the initial velocity relative to the location of the line charge. Also, the sign of the line charge would need to be specified.​
U = kq1q2d is the potential energy for two point charges, q1, q2, separated by distance d.
What is the difference in electric potential at distances dinitial & dother from an infinite line charge, with linear density, λ ?
In the picture, the proton is shot directly toward the charged line, maybe perpendicular
That's what I would expect, both directly toward the charged line, and perpendicular to it.
Do you know how electric potential varies with distance from an infinitely long line charge? If not, do you know how electric field varies with distance from an infinitely long line charge?
Hi there! Welcome to the forum. Your attempt at solving the problem is a good start. To find the nearest distance of approach, we can use the conservation of energy equation: Ki + Ui = Kf + Uf. Since the initial potential energy (Ui) is zero and the final kinetic energy (Kf) is also zero (since the proton will come to a stop at its closest approach), we can simplify the equation to: Ki = Uf. We can also substitute in the expression for potential energy: Uf = (k*q1*q2)/d. So now we have: Ki = (k*q1*q2)/d. We know the initial kinetic energy (Ki) since it is given in the problem as (1/2)*m*(v^2). So we can substitute that in as well: (1/2)*m*(v^2) = (k*q1*q2)/d. Now we can solve for d: d = (k*q1*q2)/((1/2)*m*(v^2)). This is the nearest distance of approach for the proton. We can see that it does not depend on the length of the wire, as expected for an infinite wire. I hope this helps!
FAQ: Charge density of a infinite straight wire
What is the definition of charge density?
Charge density refers to the amount of electric charge per unit length, area, or volume. In the case of an infinite straight wire, it is commonly expressed as the amount of charge per unit length along the wire.
How is the charge density of an infinite straight wire calculated?
The charge density of an infinite straight wire can be calculated by dividing the total charge of the wire by its length. It is represented by the symbol ρ (rho) and has units of coulombs per meter (C/m).
What factors affect the charge density of an infinite straight wire?
The charge density of an infinite straight wire is affected by the total charge on the wire and its length. The larger the charge or the shorter the length, the higher the charge density will be.
What is the relationship between charge density and electric field?
The charge density of an infinite straight wire is directly proportional to the electric field surrounding the wire. This means that as the charge density increases, so does the strength of the electric field.
Can the charge density of an infinite straight wire be negative?
No, the charge density of an infinite straight wire cannot be negative. It is always a positive value as it represents the amount of charge per unit length of the wire. A negative charge density would indicate a net charge deficit along the wire, which is not possible.
