Charge density using the Dirac delta funciton
In summary, the article introduces the concept of electromagnetism and its function for charge density, which is represented by the Dirac delta function. This function ensures that all the charge is concentrated at a single point, and is commonly used in physics applications to represent point masses or charges. The trajectory of the electron, denoted by ##r(t)##, is used in the equation to determine the location of the point charge. The article also discusses the current density, which is a Minkowski four-vector field, and provides a useful exercise to prove this concept.
doggydan42
170
Currently, I am reading this article which introduces electromagnetism.
It gives a function for the charge density as: $$\rho = q\delta(x-r(t))$$
The paper states that "the delta-function ensures that all the charge sits at a point," but how does it do that? Also, if ##r(t)## is the trajectory of the electron, what is its purpose in the equation?
The Dirac delta function is not a simple function but rather a more abstract mathematical object. If you consider all of the ways you can linearly map functions to numbers (called a linear functional), a great number of the more useful ones can be expressed as integrals with respect to another function.
[tex]\phi_w: f\mapsto a = \int_{-\infty}^\infty f(x)w(x) dx [/tex]
(read ##\mapsto## as "is mapped to")
The choice of weighting function or distribution ##w## determines a large class of these linear functionals but not all. For example you cannot express the linear mapping that takes a function to its value at zero (or some other fixed point). ## f\mapsto f(0)##
There is no actual function but we can invent a notation, which looks like function notation but only has meaning as a place holder inside these functional integrals.
By definition:
[tex] \int_{-\infty}^\infty f(x) \delta(x) dx = f(0) [/tex]
We can then assert that this place holder obeys the same rules a functions inside of integrals with respect to change of variable, rules of differentiation and so on.
We can thus shift the variable of integration to get:
[tex] \int_{-\infty}^\infty f(x) \delta(x-a) dx = f(a)[/tex]
This is what we have to do to give the Dirac delta function rigorous meaning mathematically. In practice you can think of it as a "function" that is infinite at one point, zero everywhere else, and is normalized to integrate to 1. It is often expressed as the limit of e.g. Gaussian distribution functions in the limit as the standard deviation goes to zero.
It is of course very handy in physics applications where you are working in a paradigm of charge or mass densities but want to introduce a point mass or point charge. Another application is instantaneous changes in velocity where one can assert the applied force and thus the acceleration took the form of a delta function (of time).
In your case the delta function ## \delta(x - r(t))## is zero everywhere except where ##x=r(t)## at which point you have the infinite spike representing the charge density. Since again the total integral of the delta function is 1, multiplying by ##q## scales it to have total charge ##q##.
Likes dextercioby
The correct equation is
$$\rho(t,\vec{x})=q \delta^{(3)}[\vec{x}-\vec{r}(t)],$$
where ##\vec{r}(t)## is the trajectory of the electron written in a fixed (inertial) reference frame.
The current density is
$$\vec{j}(t,\vec{x}) = q \dot{\vec{r}}(t) \delta^{(3)}[\vec{x}-\vec{r}(t)].$$
It is a very good exercise to prove that ##(\rho,\vec{j})## is a Minkowski four-vector field!
Hint: Write the expressions in terms of an integral over the proper time of the electron!
FAQ: Charge density using the Dirac delta funciton
What is charge density using the Dirac delta function?
Charge density using the Dirac delta function is a mathematical representation of the distribution of electric charge in a given space. The Dirac delta function is a mathematical tool used to describe the concentration of charge at a specific point in space.
How is charge density using the Dirac delta function calculated?
The charge density using the Dirac delta function is calculated by multiplying the Dirac delta function with the total charge at that point. This results in a spike at that point, representing the concentration of charge.
What is the significance of using the Dirac delta function in calculating charge density?
The Dirac delta function is used in calculating charge density because it allows for the representation of point charges or infinitely small charged objects. This is important in understanding the distribution of charge in a given space.
How does the Dirac delta function relate to the concept of charge density?
The Dirac delta function is a mathematical representation of the concentration of charge at a specific point in space, while charge density is a measure of the amount of charge per unit volume. The Dirac delta function is used to calculate charge density at a specific point in space.
What are the limitations of using the Dirac delta function to calculate charge density?
The Dirac delta function can only be used to calculate charge density at a specific point in space and does not account for the distribution of charge in surrounding areas. It also assumes that charge is concentrated at a single point, which may not always be the case in real-world situations.
