Charge distributed uniformly on sphere surface
In summary, the textbook discusses the concept of electric charge being uniformly distributed on the surface of a sphere and how it affects other charges outside the sphere as if the entire charge was concentrated at the center of the sphere. This is known as Newton's shell theorem for electrostatic forces. The proof of this theorem can be found by researching "Newton shell theorem" and can also be approached using Gauss law.
johann1301
217
From my textbook:
"An electric charge that is uniformly distributed on the surface of a sphere, affects a different charge outside the sphere as though the whole charge was collected in the center of the sphere. This we exploit when we use Coulumbs law."
Ive tried to prove this mathematically, but can't seem to do it...
If we imagine two situations:
#1:
We imagine four protons in two pairs - each pair free to move with 2e of charge - at a distance x from each other:
Fig1:(**)---------------x---------------(**)
The the force between them would be k4e2/x2
#2:
Now we imagine that we "split" the pairs in such a way that the protons in each pair are still "attached", but the charges are separated at distance of 2P. Each proton is moved a distance P from the original point in situation #1. There is still only to pairs/particles that can move:Fig2:(*-----2p-----*)----------x---------(*-----2p-----*)
Shouldn't it be possible to prove that the force between the two pairs in the last situation also should be k4e2/x2 if the original statement is correct?
(the reason for the parentheses () is to illuminate that the protons act as though the were attached to each other)
johann1301 said:
From my textbook:
This is part of Newton's shell theorem, applied to electrostatic forces, rather than gravitational forces which is the context in which Newton proved it.
Google for "Newton shell theorem" and you'll find many proofs of it.
The theorem applies to three-dimensional spherically symmetric objects, so I'm skeptical that your one-dimensional example is relevant.
Likes 1 person
You can also approach the problem using Gauss law.
Related to Charge distributed uniformly on sphere surface
What is "charge distributed uniformly on sphere surface"?
"Charge distributed uniformly on sphere surface" refers to a scenario in which electric charge is evenly spread out over the surface of a spherical object. This can occur naturally in certain substances, or it can be intentionally created in experiments.
How does the charge distribute itself on a sphere surface?
When charge is distributed uniformly on a sphere surface, it will be evenly distributed in all directions. This means that the surface of the sphere will have the same amount of charge per unit area at any point on its surface.
What is the significance of charge being distributed uniformly on a sphere surface?
This scenario is important in understanding the behavior of electric fields and forces. In this case, the electric field produced by the sphere will be isotropic, meaning it has the same strength and direction at all points on the surface. This also allows for simplified calculations when studying the behavior of the electric field.
Can charge be distributed non-uniformly on a sphere surface?
Yes, it is possible for charge to be distributed non-uniformly on a sphere surface. This can occur if the sphere has an irregular shape or if the charge is intentionally distributed in a non-uniform manner. In these cases, the electric field and forces will not be evenly distributed, and more complex calculations may be required.
What are some real-life examples of charge being distributed uniformly on a sphere surface?
One example is a charged soap bubble, where the electric charge is evenly distributed over its spherical surface. Another example is a Van de Graaff generator, which uses a spherical metal electrode with a uniform charge distribution to create static electricity. Natural phenomena such as lightning also exhibit a uniform distribution of charge on a spherical shape.
  • Electromagnetism
  • Electromagnetism
