Charge of 2 conducting spheres separated by a distance
The discussion centers on calculating the charge of two conducting spheres, one at a potential of 1500 V and the other at -1500 V, separated by 10.0 m. Initially, the charge on one sphere is calculated to be approximately 2.50×10−8 C, with a potential drop of 22.5 V at a distance of 10 m from the sphere. This drop is considered a small perturbation, allowing the assumption that the total potential can be approximated by adding this perturbation to the original 1500 V. The perturbation indicates that the influence of the second sphere is minimal, leading to a slight adjustment in the charge calculation to 2.54×10−8 C. The discussion highlights the relationship between potential, distance, and charge in electrostatics.
jolly_math
Two identical conducting spheres of radius 15.0 cm are separated by a distance of 10.0 m. What is the charge on each sphere if the potential of one is +1500 V and the other is -1500 V? Take V = 0 at infinity.
V = E∆s
V = kq/r
First assuming only one sphere at a potential of 1500 V, the charge would be q = 4πεrV = 4π(8.85×10
−12C2/N · m)(0.150 m)(1500 V) = 2.50×10−8C.
The potential from the sphere at a distance of 10.0 m would be V =(1500V)(0.150m)/(10.0m) =22.5V.
I don't understand the reasoning of the following:
This is small compared to 1500V, so we will treat it as a perturbation. This means that we can assume that the spheres have charges of
q = 4πεrV = 4π(8.85×10−12C2/N · m)(0.150 m)(1500 V + 22.5 V) = 2.54×10−8C.
What does the perturbation refer to, and how is 1500 V + 22.5 V related to the specific distance 0.150 m? Thank you.
jolly_math said:
Homework Statement:: Two identical conducting spheres of radius 15.0 cm are separated by a distance of 10.0 m. What is the charge on each sphere if the potential of one is +1500 V and the other is -1500 V? Take V = 0 at infinity.
Relevant Equations:: V = E∆s
V = kq/r
It just means that if the influence of the far sphere only drops the potential by 22.5/1500=1.5% then we can restore it to 1500V, near enough, by increasing both charges by 1.5%.
