Charge Placement where Force is Zero
In summary, Q1 and Q2 have a negative charge, so the force on Q3 is negative. However, the force on Q2 is also negative, so the total force is still negative.
jg95ae
47
I think that this problem should be easy but for some reason I don't think I really understand it.
A charge of +2q is placed at the origin and a second charge of -q is placed a x = 3cm. Where can a third charge +Q be placed so that it experiences a zero force?
I figure that F3 = F1 + F2 = k2q/x^2 - kq/(x+0.03)^2 = 0
Cancelling out and cross multiplying gives 2(x+0.03) = x^2
Therefore the eq'n is x^2 + 0.12x + 0.0018 = 0
Using the quadratic eq'n to solve I found that x = -1.8 cm or x = -10.3 cm.
Here's where I'm not sure, if they are both negative does that mean that they are to the left of the origin, and if so which is the correct one then??
Are you sure you solved that equation correctly? Check again. (How do you go from 2(x+0.03) = x^2 to x^2 + 0.12x + 0.0018 = 0?)
Sorry I left out a ^2
The eq'n should be 2(x+0.03)^2 = x^2
Therefore 2(x^2 + 0.06x + 0.0009) - x^2 =0
Which then becomes x^2 + 0.12x + 0.0018 = 0
I can't see anything wrong with this so the quadratic is still giving me negative answers.
OK, I just noticed what your real mistake was. Draw a picture. What is the distance between the particle at position "x" and the charge at .03? It isn't x + .03.
I think I see what you're saying that it should really be x - 0.03
Which would give me positive answers, one lays in between the charges, which is not correct and one be at x = 10.2 cm. Does this mean that the charge would be 10.2 cm to the right of f2, and 13.2 cm to the right of the origin?
Since x is measured from the origin, the distance from the charge at the origin when x=10.2cm is just 10.2cm. You've already given the formula that relates x to the distance from the second charge.
Ok I think I'm confused because I'm not sure that I did the first part right. Should I not have multiple q's for each force. If so I think I may have done things wrong.
I'm so confused!
I don't understand what you mean by "multiple q's for each force". What you did looks fine, except that bit about the 13.2cm from the origin.
I just meant that since its normally F = kQ1Q2/r^2
So I thought maybe I'm supposed to have F13 = k(+2q)(+q)/x^2 and so on?
OK, just to be sure, we're calling the charge at the origin Q1, the charge 3cm to the right Q2 and the test charge Q3. Then the force experienced by Q3 as a result of Q1 is:
[tex]F_{1,3}=\frac{Q_1Q_3}{x^2}[/tex]
While the force on Q3 resulting from Q2 is:
[tex]F_{2,3}=\frac{Q_2Q_3}{(x-.03)^2}[/tex]
So the total force is just the sum, keeping in mind different signs of Q1 and Q2. This is supposed to be zero. Does that clear up the confusion?
Yep I got it now, thanks for the help.
FAQ: Charge Placement where Force is Zero
What is meant by "Charge Placement where Force is Zero"?
"Charge Placement where Force is Zero" refers to the point in space where the electric force acting on a charged particle is equal to zero. This means that the force exerted by the electric field at that point is balanced by another force, such as a gravitational force or another electric force.
How is the "Charge Placement where Force is Zero" determined?
The "Charge Placement where Force is Zero" can be determined by using the principles of electrostatics and vector addition. By setting the electric force equation equal to zero and solving for the position of the charge, the point where the force is zero can be found.
What is the significance of "Charge Placement where Force is Zero" in physics?
The "Charge Placement where Force is Zero" is significant because it helps to understand the behavior and properties of electric fields. It also allows for the calculation of the electric potential at that point, which is important in many applications such as circuit design and electromagnetism.
Can the "Charge Placement where Force is Zero" change?
Yes, the "Charge Placement where Force is Zero" can change if the positions or magnitudes of the charges in the system are altered. For example, if a new charge is added to the system, the point where the force is zero will also change.
What are some real-life examples of "Charge Placement where Force is Zero"?
One example of "Charge Placement where Force is Zero" is the behavior of charged particles in a Van de Graaff generator. The point where the force is zero is at the center of the metal sphere, where the electric field is the strongest. Another example is the neutral point in a dipole, where the electric field is zero between two equal and opposite charges.
