Charged insulator with electrons throughout its volume?
In summary, the conversation discusses the possibility of creating a negatively-charged insulator by building it up layer by layer and trapping extra electrons throughout its volume. It is noted that insulators are not able to hold onto charges for very long, but there are devices such as USB sticks that operate based on a trapped charge. The conversation also addresses the limitations of injecting charges into an insulator due to mutual Coulomb repulsion and mechanical instability.
jcap
170
Could one make a negatively-charged insulator with the extra electrons trapped all the way through its volume by building it up layer by layer with electrons "sprayed" onto each layer as it was constructed?
I guess the electrons would be trapped in empty atomic orbitals within the material - is this true?
If the electron density was too high could such a material be mechanically unstable due to the electrostatic forces within it or would the electrons somehow just quantum-mechanically tunnel out of the insulator?
Insulators won’t keep that charge long. They don’t conduct well but we are talking about huge potentials for small charges.
Shooting electrons into an existing material is easier by the way.
Charges can be also injected by attaching metal contacts to opposing sides of a sample and applying a potential, as in a capacitor. The ability to inject charges into an insulator is severely limited by mutual Coulomb repulsion between them, however—the effect is called space-charge limiting.
I don't think you could 'construct' a uniformly charge dielectric that way. There is no fundamental law that would prohibit that but it is rather unlikely process.
Still, there are devices that operate based on a trapped charge. These are the USB sticks, i.e. memories that can be programmed by injecting a charge into a structure made out of a conductor separated from the sensor by an insulating layer. These charges are trapped for a pretty good time.
Related to Charged insulator with electrons throughout its volume?
1. What is a charged insulator with electrons throughout its volume?
A charged insulator with electrons throughout its volume is an object that has an excess of electrons, causing it to have an overall negative charge. Unlike conductors, insulators do not allow for the movement of electrons, so the excess electrons are spread evenly throughout the entire volume of the object.
2. How does a charged insulator with electrons throughout its volume behave?
A charged insulator with electrons throughout its volume will exhibit electrostatic forces, meaning it will attract or repel other charged objects. The strength of these forces depends on the amount of charge and distance between the objects.
3. Can a charged insulator with electrons throughout its volume be neutralized?
Yes, a charged insulator with electrons throughout its volume can be neutralized by introducing an equal amount of positive charge. This can be done by touching the insulator with a positively charged object or by adding positive ions to the insulator's surface.
4. How does a charged insulator with electrons throughout its volume differ from a charged conductor?
A charged insulator with electrons throughout its volume differs from a charged conductor in that the excess charge in the insulator is distributed evenly throughout its volume, while in a conductor, the excess charge resides on the surface. Additionally, insulators do not allow for the movement of electrons, while conductors do.
5. Can a charged insulator with electrons throughout its volume produce an electric field?
Yes, a charged insulator with electrons throughout its volume can produce an electric field. The electric field will be present both inside and outside of the insulator, but its strength will be significantly weaker compared to that of a charged conductor due to the distribution of charge throughout the volume.
  • Atomic and Condensed Matter
  • Quantum Physics
