Charging a magnetically levitating sphere to 1 gigavolt in a high vacuum
In summary: What sort of limits would be encountered if you tried to charge a magnetically levitating sphere to as high a voltage as possible in an ultra high vacuum by using an electron beam aimed at the sphere? Assume the sphere is highly spherical and polished.If electrons have sufficient energy to impact the sphere, would they stick or splash off? What if there was a hole drilled into the sphere such that the electrons impact the inside surface of the hollow sphere. Would the maximum possible charge on the sphere be higher then?The sphere would be able to hold a maximum of 1 billion volts (1 GV) of potential before it starts spewing out electrons and starts to damage the equipment.
BrandonBerchtold
46
The potential relative to infinity is Q/(4 pi eps_0 r), the field strength at the surface is Q/(4 pi eps_0 r^(2)), let's use 10 V/nm as limit, then we get r = 1GV/(10V/nm) = 10 cm. This doesn't sound bad, but direct field emission wouldn't be the limit. An electron leaving the sphere, just a stray electron from the beam, or even a random electron released from cosmic rays would hit the vacuum chamber at an energy of 1 GeV. More than enough energy to produce a couple of ions, which then accelerate towards the sphere, hitting it at an energy of 1 GeV or more. They will kick out many electrons, accelerating towards the vacuum chamber again and so on. You'll get a gigantic discharge, destroying the equipment in the process (stored energy is 5.5 MJ).
MV equipment is usually operated with SF6 as gas. It prevents this kind of discharge. You can reach something like 30 kV/mm. The same calculation as above leads to r=33 m. Good luck levitating that (electrostatic levitation sounds interesting).
In the calculation above I assumed that the other electrode is "at infinity" - which means the room would need a radius that is very large compared to 33 m. If that is impractical then the radius of the sphere must increase even more.
Oh, and did I mention that you need pressurized SF6? This giant building is like a bomb in case the pressure vessel fails.
Likes Vanadium 50, vanhees71, BrandonBerchtold and 4 others
BrandonBerchtold said:
Summary:: What sort of limits would be encountered if you tried to charge a magnetically levitating sphere in an ultra high vacuum by using an electron beam aimed at the sphere? Could you charge the sphere to a potential in the range of a gigavolt or more?
This description is full of holes.
1. What is the energy of the electron beam? If it is just the order of eV, then at some point charging effects on the sphere can easily repel the beam from hitting it.
2. What is the dimension of the sphere? This tells you how much charge it can hold before it will start spewing out its own charge.
3. What is the nature of the surface of the charge? Again, at some point, field-emission will take over. The degree of smoothness (nothing is perfectly smooth, and even grain boundaries has been shown to be center of emitters) will dictate how quickly the sphere will start leaking charges.
4. What is the UHV vessel and how big is it? There is a difference between estimating the boundary where V=0 to be far away versus something that is only 10 cm away. The distance between the sphere and the grounded walls of the UHV vessel WILL dictate the strength of the electric field gradient.
etc... Like I said, there are major holes in the details here.
Zz.
There are other practical/technological limits related to the direct field emission mechanism as well. In order to be charged to 1 GV, the surface of R=1 m sphere placed in ultrahigh vacuum must be incredibly smooth. Small irregularities (on nanometer scale) would cause powerful emission and high density currents. This kind of problems are met in medium voltage vacuum circuit breakers where the allowed max field is less than 1MV/cm
Likes BrandonBerchtold
Related to Charging a magnetically levitating sphere to 1 gigavolt in a high vacuum
1. How is a magnetically levitating sphere charged to 1 gigavolt?
To charge a magnetically levitating sphere to 1 gigavolt, a high voltage power supply is used. The power supply creates a strong electric field around the sphere, which causes electrons to be stripped from the surface of the sphere, resulting in a net positive charge.
2. What is a high vacuum and why is it necessary for charging a magnetically levitating sphere?
A high vacuum is a space where the pressure is significantly lower than the atmospheric pressure. It is necessary for charging a magnetically levitating sphere because it reduces the chances of air molecules interfering with the charging process. This allows for a more precise and controlled charging of the sphere.
3. How does magnetic levitation work in this scenario?
In this scenario, the magnetically levitating sphere is suspended in the air using strong magnetic fields. The sphere is made of a superconducting material, which allows it to repel the magnetic fields and float in mid-air. This levitation allows for the sphere to be charged without any physical contact, reducing the risk of electrical discharge.
4. What are the potential applications of charging a magnetically levitating sphere to 1 gigavolt?
Charging a magnetically levitating sphere to 1 gigavolt has potential applications in fields such as plasma physics, material science, and energy storage. It can also be used in experiments to study high voltage phenomena and to test the limits of materials under extreme conditions.
5. Are there any safety precautions that need to be taken when charging a magnetically levitating sphere to 1 gigavolt?
Yes, there are several safety precautions that need to be taken when charging a magnetically levitating sphere to 1 gigavolt. This includes wearing protective gear, working in a controlled environment, and following proper procedures to prevent electrical discharge. It is important to have trained professionals handle this process to ensure safety and avoid any accidents.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electrical Engineering
  • Electromagnetism
