Charging objects by friction & chemical reaction
In summary, rubbing a plastic rod with wool creates a triboelectric effect, which involves the exchange of electrons between molecules on the surfaces. This can result in the formation of anions and cations. The objects involved do not have free electrons, so they cannot be transferred. Applying voltage to a metallic object from a grounded battery can also produce a small static charge. Any potential difference between two objects indicates that at least one of them is charged.
simplescience
While rubbing the plastic rod with the wool causes the building up of charges on both of them.
1. What chemical reaction takes place between them.
2. Does it create anions and cations?
3. Is it the transfer of free electrons (I don't think so, because generally they are bad conductor of electricity.)
Chemistry news on Phys.org
It is called a triboelectric effect (try to google that).
Yes, have read it. But they are talking about exchange of electrons. But couldn't find out if those electrons are the
1. free electrons,
OR
2. molecules on one surface snatches away the electrons from the molecules of other surface making the snatcher as anions and the looser as cations.Do reply,
Thanks.
Neither of the objects involved has free electrons, so they are ruled out.
1. free electrons,
OR
Thanks.
Then the only possibilities are...
1. Ripping away of an electron from molecule of one surface, thus turning that molecule into a positive ion. The lost electron becomes part of the molecule of the other surface and it becomes a negative ion.
OR
2. Tearing away the Molecule of one surface making it a positive ion (or negative ion). The teared part of the molecule makes a bond with the molecule of other surface and thus makes a more complex negative ion.I think any of the above tend to happen. There is no other possibility remaining.
Kindly comment.
Thanks
Hello people I know that there are onlyfthree methods to charge an object
1 by friction or chemical reaction
2 by tribo-electro method
3 charging by induction and conduction
But can applying voltage to a metallic object from a battery who's other terminal is grounded produce static charge on that metallic object??
Yes, but it is already mentioned in your list. That would classify as charging by conduction for me.
Likes Narayanan KR
QUOTE="Borek, post: 5081879, member: 23711"]Yes, but it is already mentioned in your list. That would classify as charging by conduction for me.[/QUOTE]
Thank you sir ...So the metal will get charged right?
Yes. Typically pretty small charge, but it will be definitely there.
Whenever you have two objects and potential difference between them, you can be sure they are charged (or at least one is charged).
Thank you sir!
Related to Charging objects by friction & chemical reaction
What is charging an object by friction?
Charging an object by friction is the process of transferring electrons between two objects through rubbing or contact. This results in one object becoming positively charged and the other becoming negatively charged.
How does charging an object by friction work?
When two objects rub against each other, the friction between them causes the transfer of electrons from one object to the other. This results in one object having an excess of electrons, making it negatively charged, while the other object loses electrons and becomes positively charged.
Can all objects be charged by friction?
Yes, all objects can be charged by friction as long as they are made of materials that are good conductors of electricity, such as metal, or materials that have a high affinity for electrons, such as rubber or fur.
What is charging an object by chemical reaction?
Charging an object by chemical reaction is the process of transferring electrons between two objects through a chemical reaction. This can occur when certain materials, such as metals and acids, come into contact with each other.
How is charging an object by chemical reaction different from charging by friction?
The main difference between charging an object by chemical reaction and by friction is the mechanism of electron transfer. In charging by chemical reaction, electrons are transferred through a chemical reaction, while in charging by friction, they are transferred through rubbing or contact.
  • Electromagnetism
  • Mechanics
