Charity engineering project water projections
In summary, a first year engineering student in Christchurch, NZ is designing a water projection system for a charity project called Gap Filler. The idea is to project an image of music onto the river Avon for people to read and play along with keyboards set up nearby. The student is having trouble finding sources on how to project onto a calm flowing river. The projected image will be moving and the goal is to create an interactive and artistic space for people to hang out. The student has also contacted a projection expert and learned that the river may not be suitable for projections due to its clear water, but it could work if the water is shallow or has high sediment. The student also has a marking schedule for the project.
Buggsy GC
48
Kia ora
I'm a fist year engineering student in Christchurch NZ, and a few friend and I, are designing a simple engineering report for a water projection system for an organization called gap filler. Were currently thinking of projecting an image of music onto the river Avon so people can read the music as they pass the area and play the keyboards we are planning to set up by the river. The problem is I can't find any good sources that can explain the processes of projecting an image onto a calm flowing river. Any sources or personal knowledge about how to project images onto water, or on how to set up water projections would help. Thank you for your time everyone.
Ka kite ano
Yours sincerely Buggsy
Buggsy GC said:
Kia ora
Ka kite ano
Why do you call this a "Charity" project in your thread title?
How are people supposed to view what you project on the water? Are they on the other side of the river? Are they on a boat/ship?
What have your initial power calculations shown are needed for the projection of this image? Can you please show your calculations so far, and post a sketch of your proposed system?
With lights? You can buy a commercial projector or buy lasers or a bunch of LED spotlights...
Is it a static image? Moving (changing)? How big? How far away are you trying to project from? What research have you done on this subject?
Its an idea competition we haven't settled on the river idea yet. For instance we just learned that we would need to be able to create turbulence in the shallow river to clearly project any image. The image would be moving as we want use videos of people playing basic songs on the keyboard so pedestrians with no musical experience can try and play along. Its charity because every year gap filler gives out a handful of $15,000 budget packages to fund creative idea that satisfy the requests of different groups of Christchurch citizens and fill up abandoned sections of the city of Christchurch left over from the earthquakes. During our clients were around 200 or so local high school kids, who informed us during our interview and surveys, they want something that's artistic, interactive, musical, A cool place to hang out and instigramable. Very broad request but there was to many views to pin down a single concept, so were going with a broad idea. Here Gap fillers website it shows some of there other projects http://gapfiller.org.nz/. This report is simply about explaining how our idea could be implemented, If our idea is chosen then we have to make a report that budgets the cost of material, measure the length of the river, calculate the distance from the projector to the water screen or turbulent surface. Our marking scheduleis attached as EWB marking rubic.
how do you attach word docs to this thread
Please convert it to a PDF first (fewer virus issues) and then use the UPLOAD button in the lower right.
Sounds like a worthwhile ;project.
Sorry, that makes no sense. for example...
https://thumbs.dreamstime.com/z/white-bridge-reflected-water-surface-27683515.jpg
converted it
  • EWB marking rubric.pdf
Tom lynch of TomTom productions, has worked with projection art down in queens town, and he told me on the phone that the river Avon was to clear to get a decent projection off it, For water to be used as a screens for projections, it either has to be high in sediment, shallow or white capping.
The Avon on our slot is basically crystal clear and is about 120cm deep with a stony bottom
I would be interested in how to create turbulent flow in a river to maximize the amount of white water in a spot. A more detailed explanation than just dumping object in the targeted area of the river.
How about air bubbles thru a network of porous hoses? Perhaps add some environmentally safe foaming agent to the air injection.
injecting air into the spot through porous hoses or running the water through porous hoses to create air bubbles. Also there plenty of organic mater in the river so it shouldn't be hard to get the water foaming if i can create some small rapids. I'm just having trouble finding a description of how to maximize rapids in one spot
Related to Charity engineering project water projections
What is a charity engineering project?
A charity engineering project is a project that aims to use engineering principles and methods to address a social or environmental issue and benefit vulnerable communities or individuals. Examples of such projects include building wells to provide clean water, designing and constructing sustainable housing, or developing renewable energy sources for remote areas.
How does a charity engineering project help with water projections?
A charity engineering project can help with water projections by using engineering techniques to analyze and forecast water availability and usage in a specific area. This information can then be used to design and implement solutions to ensure sustainable access to clean water for the community. This may involve building rainwater harvesting systems, constructing wells or water treatment facilities, or implementing water conservation measures.
What factors are considered when creating water projections for a charity engineering project?
When creating water projections for a charity engineering project, factors such as climate, geography, population, and water usage patterns are taken into account. Other considerations may include the availability of resources, local infrastructure, and cultural practices. It is also important to involve community members and stakeholders in the planning process to ensure the project meets their needs and is sustainable in the long term.
What are the potential challenges of implementing a charity engineering project for water projections?
Some potential challenges of implementing a charity engineering project for water projections may include financial constraints, limited resources, and technical difficulties. Additionally, cultural and political barriers may also arise, and it is important to navigate these challenges with sensitivity and collaboration with the local community. It is also crucial to continuously monitor and evaluate the project to ensure its effectiveness and sustainability.
How can individuals get involved in charity engineering projects for water projections?
Individuals can get involved in charity engineering projects for water projections by volunteering their time and skills, donating to organizations that support such projects, or advocating for policies and initiatives that address water-related issues. It is also important to educate yourself and others about the global water crisis and the importance of sustainable engineering solutions to address it.
