Cheap liquid with Sp.Gravity betn. 2.8 to 6.5
  • Thread starter biren
  • Tags
    Liquid
In summary, the person is looking for a liquid that is cheap, easy to find, safe to use (non-toxic and non-acidic), usable at room temperature, and has a viscosity less than 10 cp and a specific gravity between 2.8 to 6.5. They ask for help and someone suggests checking a thread on Physics Forums where sodium polytungstate solutions are mentioned as a possible option due to its low viscosity and non-toxic nature, although it may not be very cheap.
biren
i am trying to find a liquid that is -
cheaply and easily available;
easy and safe to use - non-toxic, non-acidic;
usable at room temperatures;
with a viscosity less than 10 cp;
and specific gravity anywhere between 2.8 to 6.5...
please help?
thanks a bunch
warm regards
b.
Chemistry news on Phys.org
Sodium polytungstate solutions have a density of up to 3.10 at relatively low viscosity and non-toxic. Not exactly cheap, but probably the only liquid which is non-toxic in that density range:
http://www.geoliquids.com/geo_pdfs/msds_sp.pdf
Related to Cheap liquid with Sp.Gravity betn. 2.8 to 6.5
What is the definition of specific gravity?
Specific gravity is a measurement of the density of a substance compared to the density of water. It is often used to determine the purity or composition of a liquid.
What is considered a low specific gravity for a liquid?
In general, a specific gravity of less than 1.0 indicates a liquid that is less dense than water and will float on top of it. However, for the specific gravity range of 2.8 to 6.5, a low specific gravity would be closer to 2.8.
How is specific gravity measured?
Specific gravity is typically measured using a hydrometer, which is a device that measures the density of a liquid by how high it floats in the liquid. The measurement is then compared to the density of water to determine the specific gravity.
What types of liquids have a specific gravity between 2.8 and 6.5?
Liquids with a specific gravity in this range can include various types of oils, alcohols, and other chemicals. These liquids are typically more dense than water and will sink in it.
Is specific gravity related to the cost of a liquid?
No, specific gravity is not directly related to the cost of a liquid. It is simply a measurement of density and does not determine the quality or value of a substance.
  • Atomic and Condensed Matter
  • Materials and Chemical Engineering
  • Earth Sciences
61K
9K
  • General Engineering
10K
