Check answers to critical point, extrema questions
In summary, a critical point in mathematics is a point where the derivative of a function is equal to zero or undefined, indicating a potential maximum or minimum. To find critical points, take the derivative of the function and set it equal to zero, then solve for the variable. An extrema point is a point where the function reaches a maximum or minimum value, which can be determined by finding the critical points and evaluating the function. To determine if a critical point is a maximum or minimum, you can use the first or second derivative test. Critical points and extrema are important in mathematics because they help us understand the behavior of a function and are essential in optimization problems. They also help us determine intervals of increasing or decreasing values for a function.
tjohn101
93
If my answers to the questions in the attachments could be checked that would be great. All work is done, and the questions in the pictures are fairly quick and simple. I want to be sure I got them correct.
Thank you!
Is it just me, or does everyone like those choices? When f(x) has an absolute minimum value on the interval [itex][0, \infty)[/itex] of 2 when x = 1, I don't consider the answer to "find the absolute minimum for f(x)" of (1,2) to be correct. The answer should be 2.
FAQ: Check answers to critical point, extrema questions
1. What is a critical point in mathematics?
A critical point in mathematics is a point where the derivative of a function is equal to zero or undefined. This means that the slope of the graph at that point is either horizontal or vertical, indicating a potential maximum or minimum.
2. How do you find critical points in a function?
To find critical points in a function, you need to take the derivative of the function and set it equal to zero. Then, solve for the variable to find the x-values of the critical points.
3. What is an extrema point?
An extrema point is a point where the function reaches either a maximum or minimum value. This can be determined by finding the critical points and evaluating the function at those points.
4. How do you determine if a critical point is a maximum or minimum?
To determine if a critical point is a maximum or minimum, you can use the first or second derivative test. The first derivative test involves evaluating the slope of the function on either side of the critical point. If the slope changes from positive to negative, the critical point is a maximum. If the slope changes from negative to positive, the critical point is a minimum. The second derivative test involves evaluating the concavity of the function at the critical point. A positive second derivative indicates a minimum while a negative second derivative indicates a maximum.
5. Why are critical points and extrema important in mathematics?
Critical points and extrema are important in mathematics because they help us understand the behavior of a function. They allow us to identify maximum and minimum values, which are essential in optimization problems. Additionally, they help us determine the intervals where a function is increasing or decreasing.
