Do These Integrals Converge or Diverge?
In summary, the integrals 1, 2, and 3 are all convergent. For the first integral, the upper bound of $te^{-t}$ was used to show convergence. For the second integral, the upper bound of $\frac{1}{t^{\alpha}}$ was used, with $\alpha$ being any power. And for the third integral, the method of partial integration was used to split the integral and find an upper bound for each part, leading to the overall convergence of the integral.
mathmari
MHB
5,049
Hey! :giggle:
I want to check if the following integrals converge or diverge.
1 . $\displaystyle{\int_0^{+\infty}t^2e^{-t^2}\, dt}$
2. $\displaystyle{\int_e^{+\infty}\frac{1}{t^n\ln t}\, dt, \ n\in \{1,2\}}$
3. $\displaystyle{\int_0^{+\infty}\frac{\sin t}{\sqrt{t}}\, dt}$
4. $\displaystyle{\int_0^{+\infty}e^{-t^2}\, dt}$
5. $\displaystyle{\int_1^{+\infty}\frac{(\ln t)^{\beta}}{t^{\alpha}}\, dt, \alpha ,\beta\in \mathbb{R}}$
6. $\displaystyle{\int_0^{+\infty}\frac{t\ln t}{(1-t^2)^2}\, dt}$
7. $\displaystyle{\int_1^{+\infty}\frac{|\sin t|}{t}\, dt}$
8. $\displaystyle{\int_0^{+\infty}t^ne^{-at}\, dt, \ a>0}$
9. $\displaystyle{\int_1^{+\infty}\frac{|\cos t|}{t^2}\, dt}$ Let's consider first the three first integrals...
For the integral 1 I have done the following:
It holds that $\left |t^2e^{-t^2}\right |\leq te^{-t}$ and that $\displaystyle{\int_0^{+\infty}te^{-t}\, dt=1<\infty}$. Therefore also the integral $\displaystyle{\int_0^{+\infty}t^2e^{-t^2}\, dt}$ converges. For question 2 the integral diverges, or not?So wehave to take a smaller integral that can be computed to show that the smaller one diverges and so also the origonal integral, right? But what bound do we take? For question 3 I thought to take $\left |\frac{\sin t}{\sqrt{t}}\right |=\frac{|\sin t|}{|\sqrt{t}|}\leq \frac{t}{\sqrt{t}}=\sqrt{t}$ but the integral of $\sqrt{t}$ diverges. The same holds if we take $|\sin t|<1$ instead of $|\sin t|<t$. Which bound do we take here? :unsure:
Hey mathmari!
How can we tell that $\left |t^2e^{-t^2}\right |\leq te^{-t}$? :unsure:
How about $\frac{1}{t^\alpha}$? :unsure:
Suppose we try partial integration first? That is $\int u\,dv = u\,v-\int v\,du$. :unsure:
A good question... This proof is a bit difficult because of the powers at the exponential, isn't it? Is there an other upper bound that we could use? :unsure:
By $a$ you mean $n$ ? :unsure:
But does this help us?
We have \begin{equation*}\int_0^{+\infty}\frac{\sin t}{\sqrt{t}}\, dt=\int_0^{+\infty}\frac{1}{\sqrt{t}}\cdot \left (-\cos t\right )'\, dt=\left [\frac{1}{\sqrt{t}}\cdot \left (-\cos t\right )\right ]_0^{+\infty}-\int_0^{+\infty}\left (\frac{1}{\sqrt{t}}\right )'\cdot \left (-\cos t\right )\, dt\end{equation*} The limit of $\frac{1}{\sqrt{t}}\cdot \left (-\cos t\right )$ at $0$ doesn't exist. :unsure:
Perhaps we can use $t^2 e^{-t^2} < t^2 e^{-t}$ for sufficiently large $t$? :unsure:
Or alternatively we could do a partial integration first. 🤔
I meant a power $\alpha$ that could be anything.
Note that for sufficiently large $t$ we have $\frac 1{t^3} <\frac 1{t^2\ln t} <\frac 1{t^2} <\frac 1{t^{1.01}} < \frac 1{t\ln t} < \frac 1{t}$. 🤔
Suppose we split the integral into a part from $0$ to $1$ and a part from $1$ to $\infty$.
Can we find an upper bound for the first part for the original integral?
And an upper bound for the second part after the partial integration? 🤔
For $n=1$ you can integrate it explicitly: $\displaystyle \int \frac1{t\ln t}\,dt = \ln(\ln t)$.
When we do partial integration we get the integral $\int_0^{+\infty}e^{-t^2}\, dt$, right? Do we want to find now for $e^{-t^2}$ an upper bound? :unsure:
But $e^{-t^2}\leq e^{-t}$ holds only for $t\geq 1$. So either we have to find an other upper bound or we have to split the integral into a sum of two integrals, but what could we do then with the integral on $[0,1]$ ?
:unsure:
We have the following: \begin{equation*}\int_0^{+\infty}\frac{\sin t}{\sqrt{t}}\, dt=\int_0^{1}\frac{\sin t}{\sqrt{t}}\, dt+\int_1^{+\infty}\frac{\sin t}{\sqrt{t}}\, dt\end{equation*}
- $\displaystyle{\int_0^{1}\frac{\sin t}{\sqrt{t}}\, dt}$ :
We have that $\left |\frac{\sin t}{\sqrt{t}}\right |\leq \frac{t}{\sqrt{t}}=\sqrt{t}$ and $\int_0^1 \sqrt{t} \, dt=\left [\frac{2t^{3/2}}{3}\right ]_0^1=\frac{2}{3}<\infty$. So also the integral $\displaystyle{\int_0^{1}\frac{\sin t}{\sqrt{t}}\, dt}$ converges.
- $\displaystyle{\int_1^{+\infty}\frac{\sin t}{\sqrt{t}}\, dt}$ :
Using partial integration we get \begin{align*}\int_1^{+\infty}\frac{\sin t}{\sqrt{t}}\, dt&=\int_1^{+\infty}\frac{1}{\sqrt{t}}\cdot \left (-\cos t\right )'\, dt=\left [\frac{1}{\sqrt{t}}\cdot \left (-\cos t\right )\right ]_1^{+\infty}-\int_1^{+\infty}\left (\frac{1}{\sqrt{t}}\right )'\cdot \left (-\cos t\right )\, dt \\ & =\lim_{t\rightarrow +\infty}\frac{-\cos t}{\sqrt{t}}-\left (\frac{-\cos 1}{\sqrt{1}}\right )+\int_1^{+\infty}\left (-\frac{1}{2t^{3/2}}\right )\cdot \cos t \, dt \\ & =\cos 1-\int_1^{+\infty} \frac{\cos t}{2t^{3/2}} \, dt\end{align*}
We have that $\left |\frac{\cos t}{2t^{3/2}}\right |\leq \frac{1}{2t^{3/2}}$ und $\int_1^{+\infty} \frac{1}{2t^{3/2}} \, dt=\left [-\frac{1}{\sqrt{t}}\right ]_1^{+\infty}=0+1=1<\infty$. So also the integral $\displaystyle{\int_1^{+\infty} \frac{\cos t}{2t^{3/2}} \, dt}$ converges.
So also the integral $\displaystyle{\int_1^{+\infty}\frac{\sin t}{\sqrt{t}}\, dt}$ converges.
Therefore we get the convergence also of $\displaystyle{\int_0^{+\infty}\frac{\sin t}{\sqrt{t}}\, dt}$.
:unsure:
So we have to consider the cases $n=1$ and $n=2$ seperately, right? :unsure:
I think so, yes.
Opalg said:
I think so, yes.
Ah ok!
So we have:
For $n=1$ : $\displaystyle \int_e^{+\infty} \frac1{t\ln t}\,dt = \left [\ln(\ln t)\right ]_e^{+\infty}= \lim_{t\rightarrow +\infty}\ln(\ln t)=+\infty$, so we see that this integral doesn't converge.
For $n=2$, using the inequalities of post #4 we get that $\left |\frac{1}{t^2\ln t}\right |\leq \frac{1}{t^2}$ and since $\displaystyle \int_e^{+\infty} \frac{1}{t^2}\,dt =\left [-\frac{1}{t}\right ]_e^{+\infty}=\frac{1}{e}<\infty$. So also the integral $\displaystyle \int_e^{+\infty} \frac1{t^2\ln t}\,dt$ converges.
Is everything correct? :unsure:
mathmari said:
Ah ok!
So we have:
(up)
The integral of a bounded function on a bounded interval is finite isn't it? 🤔
Looks good to me. (Nod)
Using partial integration we get \begin{align*}\int_0^{+\infty}t^2e^{-t^2}\, dt&=\int_0^{+\infty}t\cdot \frac{1}{-2}\cdot \left (-2te^{-t^2}\right )\, dt =-\frac{1}{2}\cdot \int_0^{+\infty}t\cdot \left (e^{-t^2}\right )'\, dt\\ & =-\frac{1}{2}\cdot \left (\left [t\cdot e^{-t^2}\right ]_0^{+\infty}- \int_0^{+\infty}\left (t\right )'\cdot e^{-t^2}\, dt\right ) \\ & =-\frac{1}{2}\cdot \left (\lim_{t\rightarrow +\infty}t\cdot e^{-t^2}-0\cdot e^{-0^2}- \int_0^{+\infty}1\cdot e^{-t^2}\, dt\right ) \\ & =-\frac{1}{2}\cdot \left (\lim_{t\rightarrow +\infty}\frac{t}{e^{t^2}}- \int_0^{+\infty} e^{-t^2}\, dt\right ) \\ & \ \overset{\text{De L'Hospital}}{ = } \ -\frac{1}{2}\cdot \left (\lim_{t\rightarrow +\infty}\frac{1}{2te^{t^2}}- \int_0^{+\infty} e^{-t^2}\, dt\right ) \\ & = -\frac{1}{2}\cdot \left (0- \int_0^{+\infty} e^{-t^2}\, dt\right ) \\ & = \frac{1}{2}\cdot\int_0^{+\infty} e^{-t^2}\, dt \\ & = \frac{1}{2}\cdot \left (\int_0^1 e^{-t^2}\, dt+\int_1^{+\infty} e^{-t^2}\, dt\right )\end{align*}
It holds that \begin{equation*}0<t<1 \Rightarrow 0<t^2<1 \Rightarrow -1<-t^2<0 \Rightarrow e^{-1}<e^{-t^2}<e^0 \Rightarrow \frac{1}{e}<e^{-t^2}<1\end{equation*}
The integral of a bounded function on a bounded interval is finite. So we have that $\displaystyle{\int_0^1 e^{-t^2}\, dt<\infty}$.
For $t\geq 1$ it holds that $\displaystyle{|e^{-t^2}|=e^{-t^2}\leq e^{-t}}$ and $\displaystyle{\int_1^{+\infty} e^{-t}\, dt=\left [ -e^{-t}\right ]_1^{+\infty}=\lim_{t\rightarrow +\infty}\left ( -e^{-t}\right )- \left ( -e^{-1}\right )=-\lim_{t\rightarrow +\infty}\frac{1}{e^{t}}+\frac{1}{e}=-0+\frac{1}{e}=\frac{1}{e}<\infty}$.
So also the integral $\displaystyle{\int_1^{+\infty} e^{-t^2}\, dt}$ converges.
Therefore we get the convergence of $\displaystyle{\int_0^{+\infty}t^2e^{-t^2}\, dt}$. Is that correct? :unsure:
At integral #5 do we have to take cases for $\alpha$ and $\beta$ ?At integral #6 :
Do we use that $$\left |\frac{t\ln t}{(1-t^2)^2}\right | \leq \frac{t \cdot t}{(1-t^2)^2}=\frac{t^2}{(1-t^2)^2}$$ Or can we get a better upper bound?
At integral #7 :
We have that $$\left |\frac{|\sin t|}{t}\right |=\frac{|\sin t|}{t}\leq \frac{t}{t}=1$$ But that doesn't help us, since the integral of $1$ doesn't converge.At integral #8 :
Do we use partial integration?At integral #9 :
We have that $\displaystyle{\left |\frac{|\cos t|}{t^2}\right |=\frac{|\cos t|}{t^2}\leq \frac{1}{t^2}}$ and $\displaystyle{\int_1^{+\infty}\frac{1}{t^2}\, dt=\left [-\frac{1}{t}\right ]_1^{+\infty}=1<\infty}$. So we get also convergence of $\displaystyle{\int_1^{+\infty}\frac{|\cos t|}{t^2}\, dt}$.:unsure:
Nothing new, but two other thoughts about integral 3:
After substituting \( t=x^2 \) one obtains the integral \[ \textrm{constant} \cdot \int_0^{\infty} \sin (x^2) \textrm{d}x, \] which is a standard integral known to converge.Another way to proceed:
\[ \begin{align*}\int_0^{\infty} \frac{\sin (t)}{\sqrt{t}}\textrm{d}t &= \sum_{v=0}^{\infty} \int_{v\pi}^{(v+1)\pi} \frac{\sin (t)}{\sqrt{t}} \textrm{d}t \\
&< \pi + \sum_{v=1}^{\infty} \frac{(-1)^v}{\sqrt{v\pi}} \\
&< \pi + \frac{1}{\sqrt{2\pi}},\end{align*}\]
because alternating sum converges.
At integral #6 I have done the following:
We have that \begin{equation*}\int_0^{+\infty}\frac{t\ln t}{(1-t^2)^2}\, dt=\int_0^1\frac{t\ln t}{(1-t^2)^2}\, dt+\int_1^{+\infty}\frac{t\ln t}{(1-t^2)^2}\, dt\end{equation*}
In the interval $[0,1]$ we have that \begin{equation*}\left |\frac{t\ln t}{(1+t^2)^2}\right |\leq \frac{t\cdot \frac{1}{t}}{t^4}=\frac{1}{t^4}<1\end{equation*}
The integral of a bounded function in a bounded intervall is finite.
In the Interval $[1, +\infty)$ we have that \begin{equation*}\left |\frac{t\ln t}{(1+t^2)^2}\right |\leq \frac{t\cdot t}{t^4}=\frac{t^{2}}{t^4}=t^{-2}\end{equation*} and \begin{equation*}\int_1^{+\infty}t^{-2}\, dt=\left [-\frac{1}{t}\right ]_1^{+\infty}=\lim_{t\rightarrow +\infty}\left (-\frac{1}{t}\right )-\left (-\frac{1}{1}\right )=0+1=1\end{equation*}
So also the integral $\displaystyle{\int_1^{+\infty}\frac{t\ln t}{(1-t^2)^2}\, dt}$ converges.
Therefore we get also the convergence of $\displaystyle{\int_0^{+\infty}\frac{t\ln t}{(1-t^2)^2}\, dt}$.Is that correct? :unsure:
At integral #7 I have done the following:
We have that \begin{equation*}\displaystyle \int_1^\infty \frac{|\sin(x)|}{x} \,\mathrm{d}x = \int_1^\pi \frac{|\sin(x)|}{x} \,\mathrm{d}x + \sum_{k=1}^\infty \int_{k\pi}^{(k+1)\pi} \frac{|\sin(x)|}{x} \,\mathrm{d}\end{equation*}
The first term is finite, so we have to check the convergnce of the series.
It holds that \begin{align*}\sum_{k=1}^\infty \int_{k\pi}^{(k+1)\pi} \frac{|\sin(x)|}{x} \,\mathrm{d}x &\geq \sum_{k=1}^\infty \int_{k\pi}^{(k+1)\pi} \frac{|\sin(x)|}{(k+1)\pi} \,\mathrm{d}x = \frac{1}{\pi} \sum_{k=1}^\infty \frac{1}{k+1}\int_{k\pi}^{(k+1)\pi} |\sin(x)| \,\mathrm{d}x \\ & = \frac{1}{\pi} \sum_{k=1}^\infty \frac{1}{k+1}\left [-\text{sgn}(\sin(x))\cdot \cos (x)\right ]_{k\pi}^{(k+1)\pi}\end{align*}
Is that correct? Do we get now the harmonic series?
:unsure:
mathmari said:
Is that correct?
Looks correct to me. (Nod)
For any $\alpha,\beta >0$ we have that $(\ln t)^\beta < t^\alpha$ for sufficiently large $t$.
Additionally we know that $\int_1^{+\infty}\frac 1 t\,dt$ diverges and that for $\alpha>0$ that $\int_1^{+\infty}\frac 1 {t^{1+\alpha}}\,dt$ converges.
So I guess we have to find where the boundaries are for $\alpha$ and $\beta$ so that we get either convergence or divergence. 🤔
We have $$\frac{t^2}{(1-t^2)^2} = \frac{1}{(1-t^2)^2} - \frac{1-t^2}{(1-t^2)^2}$$
don't we? 🤔
Btw, we can't just replace $(1-t^2)^2$ by $(1+t^2)^2$ can we? :oops:
Yes, we get the harmonic series since the integrated part can be made independent of $k$. 🤔
At integral #8 :
Let's try. (Sweating)
At integral #9 :
Yep. (Nod)
For $\alpha,\beta >0$ do we have that $(\ln t)^\beta < t^\alpha$ if $\beta \leq \alpha$ ? :unsure:
We have that $(\ln t)^\beta < t^\alpha< t^{\alpha+2}$ and so we get $\frac{(\ln t)^\beta}{t^\alpha}<\frac{1}{t^2}$ and since $\int_1^{+\infty}\frac 1 {t^2}\,dt=\left [-\frac{1}{t}\right ]_1^{+\infty}=1<\infty$ and so we get convergence also for the integral $\displaystyle{\int_1^{+\infty}\frac{(\ln t)^{\beta}}{t^{\alpha}}\, dt}$.
So now we have to check also the cases "$\alpha>0$ & $\beta<0$", "$\alpha<0$ & $\beta>0$" and "$\alpha<0$ & $\beta<0$", right? :unsure:
don't we? 🤔
Ah yes... I thought my mistake that we had "+" instead of "-". (Tmi)
So in the interval $[1, +\infty)$ we have $$\left |\frac{t\ln t}{(1-t^2)^2}\right |\leq \frac{t\cdot t}{(1-t^2)^2}=\frac{t^2}{(1-t^2)^2}= \frac{1}{(1-t^2)^2} - \frac{1-t^2}{(1-t^2)^2}= \frac{1}{(1-t^2)^2} - \frac{1}{1-t^2}$$ The second part is positive, isn't it? :unsure:
We have that \begin{align*}\left [-\text{sgn}(\sin(x))\cdot \cos (x)\right ]_{k\pi}^{(k+1)\pi}&=\left (-\text{sgn}(\sin((k+1)\pi))\cdot \cos ((k+1)\pi)\right )-\left (-\text{sgn}(\sin(k\pi))\cdot \cos (k\pi)\right )\\ & =-\text{sgn}(\sin((k+1)\pi))\cdot (-1)^{k+1}+\text{sgn}(\sin(k\pi))\cdot (-1)^k\end{align*}
Since $\sin((k+1)\pi)=\sin(k\pi)=0$ we get that $\text{sgn}(\sin((k+1)\pi))=\text{sgn}(\sin(k\pi))=0$, or not? So do we get the series of $0$ ? :unsure:
I think that first we have to split the integral into the sum $$\int_0^{+\infty}t^ne^{-at}\, dt=\int_0^1t^ne^{-at}\, dt+\int_1^{+\infty}t^ne^{-at}\, dt$$
We have that $\left |\frac{t^n}{e^{at}}\right |=\frac{t^n}{e^{at}}\leq \frac{1^n}{e^{a\cdot 0}}=1$, since $t\in [0,1]$, or not?
Is that is correct, then we have that the integral of a bounded function on a bounded interval is finite.
:unsure: We have that \begin{align*}\int_1^{+\infty}t^ne^{-at}\, dt&=\int_1^{+\infty} \frac{t^n}{-a} \left (e^{-at}\right )'\, dt \\ & =\left [\frac{t^n}{-a} e^{-at}\right ]_1^{+\infty}-\int_1^{+\infty} \left (\frac{t^n}{-a}\right )' e^{-at}\, dt\\ & =\frac{1}{ae^a} -\int_1^{+\infty} \frac{nt^{n-1}}{-a} e^{-at}\, dt \\ & =\frac{1}{ae^a} -\int_1^{+\infty} \frac{nt^{n-1}}{a^2} \left (e^{-at}\right )'\, dt \\ & =\frac{1}{ae^a} -\frac{n}{ae^a}+\int_1^{+\infty} \frac{n(n-1)t^{n-2}}{a^2}e^{-at}\, dt\end{align*}
We if continue we get at the end a sum of the form $\frac{1}{ae^a} -\frac{n}{ae^a}+\frac{n(n-1)}{ae^a} -\frac{n(n-1)(n_2)}{ae^a}+\cdots+\int_1^{+\infty} \frac{n!}{a^n}e^{-at}\, dt$ which can be calculated, or not?
Or is it better to get an upper bound to show the convergence?
:unsure:
It must be positive yes.
But more importantly we now have 2 terms that we can integrate separately.
If both integrations are finite, then their difference is finite as well. 🤔
The sign function is a bit confusing here. It is not actually supposed to result in an evaluation of $0$ at the end points.
Perhaps it's better to avoid the sign function and instead integrate separately on $[2\pi k, 2\pi k + \pi]$ and $[2\pi k + \pi, 2\pi k + 2\pi]$.
Then we don't need the sign function and we'll see that the contributions are indeed not zero. 🤔
Suppose we don't split the domain but only apply partial integration.
Don't we get a simpler series then? 🤔
We can also evaluate the integral at the end, can't we? 🤔
I checked the integral in Wolfram but this doesn't converge. So we have to find an other upper bound, right? :unsure:
Ah, I overlooked that we have a singularity at $t=1$.
If we integrate starting from $t=2$ we do have convergence.
I think that instead of an upper bound we need to find a lower bound to prove that e.g. the integral from $1$ to $2$ does not converge. 🤔
I don't really find an appropriate lower bound that helps us.
For example in the intervall $[0,1]$ a lower bound is $t\ln t$.
Then it holds also $\ln t\leq t$ for $t\geq 1$ or $\ln t\leq \frac{1}{t}$ for $t\in [0,1]$.
These inequalities are correct, aren't they? :unsure:
But using these ones we don't get an appropriate result, do we?
Could you give me a hint?
:unsure:
$\ln t$ is negative In the interval $(0,1)$ and the function is negative as well, which makes it a bit confusing. o_O
Suppose we focus on the interval $[1,2]$.
Then $\ln t \ge \frac 12(t-1)$ isn't it? 🤔
If \( t \approx 1 \), then \[ \ln t > 2 \frac{t-1}{t+1}. \]
Which means
\[ \frac{t \ln t}{(1 - t^2)^2} > \frac{2t}{(1+t)^2(1-t)^2} \frac{t-1}{t+1} = \frac{-2t}{(t+1)^3(1-t)} . \]
Does this help? :unsure:
Why does this inequality hold? :unsure:
Theia said:
Which means
So we use this inequality in the interval $[0,1]$ or $[1,2]$ and we get divergence, right? :unsure:
Perhaps it's better to avoid the sign function and instead integrate separately on $[2\pi k, 2\pi k + \pi]$ and $[2\pi k + k, 2\pi k + 2\pi]$.
We have that \begin{align*}\sum_{k=1}^\infty \int_{k\pi}^{(k+1)\pi} \frac{|\sin(x)|}{x} \,\mathrm{d}x &\geq \sum_{k=1}^\infty \int_{k\pi}^{(k+1)\pi} \frac{|\sin(x)|}{(k+1)\pi} \,\mathrm{d}x = \frac{1}{\pi} \sum_{k=1}^\infty \frac{1}{k+1}\int_{k\pi}^{(k+1)\pi} |\sin(x)| \,\mathrm{d}x \\ & = \frac{1}{\pi} \sum_{k=1}^\infty \frac{1}{k+1}\left (\int_{(2k-1)\pi}^{(2k)\pi} |\sin(x)| \,\mathrm{d}x +\int_{(2k)\pi}^{(2k+1)\pi} |\sin(x)| \,\mathrm{d}x \right ) \\ & = \frac{1}{\pi} \sum_{k=1}^\infty \frac{1}{k+1}\left (\int_{(2k-1)\pi}^{(2k)\pi} \left (-\sin(x)\right ) \,\mathrm{d}x +\int_{(2k)\pi}^{(2k+1)\pi} \sin(x) \,\mathrm{d}x \right ) \\ & = \frac{1}{\pi} \sum_{k=1}^\infty \frac{1}{k+1}\left ( \left [\cos(x)\right ]_{(2k-1)\pi}^{(2k)\pi} + \left [-\cos(x)\right ]_{(2k)\pi}^{(2k+1)\pi} \right ) \\ & = \frac{1}{\pi} \sum_{k=1}^\infty \frac{1}{k+1}\left ( \left [\cos(x)\right ]_{(2k-1)\pi}^{(2k)\pi} - \left [\cos(x)\right ]_{(2k)\pi}^{(2k+1)\pi} \right ) \\ & = \frac{1}{\pi} \sum_{k=1}^\infty \frac{1}{k+1}\left (\left [ (-1)^{2k}-(-1)^{(2k-1)} \right ] -\left [ (-1)^{2k+1}-(-1)^{(2k)} \right ] \right ) \\ & = \frac{1}{\pi} \sum_{k=1}^\infty \frac{1}{k+1}\cdot 4 \\ & = \frac{4}{\pi} \sum_{k=1}^\infty \frac{1}{k+1}\end{align*}
The harmonic series is $\displaystyle{\sum_{k=1}^{\infty}\frac{1}{k}}$ we have the series that starts from the second term, right?
So we have that $$k<k+1 \Rightarrow \frac{1}{k}>\frac{1}{k+1} \Rightarrow \sum_{k=1}^\infty \frac{1}{k}> \sum_{k=1}^\infty \frac{1}{k+1}$$ Since $\displaystyle{\sum_{k=1}^{\infty}\frac{1}{k}}$ diverges then it doesn't follow that the smaller one $\displaystyle{\sum_{k=1}^{\infty}\frac{1}{k+1}}$ diverges, does it?
:unsure:
\begin{align*}\int_0^{+\infty}t^ne^{-at}\, dt&=\int_0^{+\infty} \frac{t^n}{-a} \left (e^{-at}\right )'\, dt \\ & =\left [\frac{t^n}{-a} e^{-at}\right ]_0^{+\infty}-\int_1^{+\infty} \left (\frac{t^n}{-a}\right )' e^{-at}\, dt\\ & =0 -\int_0^{+\infty} \frac{nt^{n-1}}{-a} e^{-at}\, dt \\ & = -\int_0^{+\infty} \frac{nt^{n-1}}{a^2} \left (e^{-at}\right )'\, dt \\ & =\int_0^{+\infty} \frac{n(n-1)t^{n-2}}{a^2}e^{-at}\, dt \\ & = \ldots \\ & = \int_0^{+\infty} \frac{n!}{a^n}e^{-at}\, dt \\ & = \frac{n!}{a^n}\cdot \int_0^{+\infty} e^{-at}\, dt \\ & = \frac{n!}{a^n}\cdot \left [e^{-at}\right ]_0^{+\infty} \\ & = -\frac{n!}{a^n}<\infty\end{align*}
So the integral converges.
A small correction to my post: must be \( t>1. \) For \( t < 1 \) the > sign turns to <.
The reason why this holds, is the series representation of logarithm:
\[ \ln x = 2\sum_{v=0}^{\infty} \frac{1}{2v+1} \left( \frac{x-1}{x+1} \right)^{2v+1} \]
Yes.
Yes.
Sowe have that \begin{equation*}\int_0^{+\infty}\frac{t\ln t}{(1-t^2)^2}\, dt=\int_0^1\frac{t\ln t}{(1-t^2)^2}\, dt+\int_1^2\frac{t\ln t}{(1-t^2)^2}\, dt+\int_2^{+\infty}\frac{t\ln t}{(1-t^2)^2}\, dt\end{equation*}
In the interval $[1, 2]$ we have that \begin{equation*}\ln t = 2\sum_{v=0}^{\infty} \frac{1}{2v+1} \left( \frac{t-1}{t+1} \right)^{2v+1}\geq 2\cdot \frac{t-1}{t+1} \end{equation*}
That's why we have that:
\begin{align*}\frac{t\ln t}{(1-t^2)^2}&=\frac{t}{(1-t^2)^2}\cdot \ln t\geq \frac{t}{(1-t^2)^2}\cdot 2\cdot \frac{t-1}{t+1}=\frac{2t}{\left ((1-t)(1+t)\right )^2}\cdot \frac{t-1}{t+1} \\ & =\frac{2t}{(1-t)^2(1+t)^2} \cdot \left (-\frac{1-t}{t+1}\right ) =-\frac{2t}{(1-t)(1+t)^3} \end{align*} und \begin{align*}\int_1^2\frac{-2t}{(1-t)(1+t)^3}\, dt=& \int_1^2-\left (-\frac{1}{4 (-1 + t)} - \frac{1}{(1 + t)^3} + \frac{1}{2 (1 + t)^2} + \frac{1}{4 (1 + t)}\right ) \, dt \\ =& \int_1^2\frac{1}{4 (-1 + t)}\, dt + \int_1^2\frac{1}{(1 + t)^3}\, dt - \int_1^2\frac{1}{2 (1 + t)^2}\, dt - \int_1^2\frac{1}{4 (1 + t)}] \, dt \\ = & \left [\frac{1}{4}\ln (t-1)\right ]_1^2 + \left [-\frac{1}{2(t+1)^2}\right ]_1^2 - \left [-\frac{1}{2(t+1)}\right ]_1^2 - \left [\frac{1}{4}\ln (t+1)\right ]_1^2 \\ = & \frac{1}{4}\ln (2-1)-\lim_{t\rightarrow 1}\frac{1}{4}\ln (t-1) - \frac{1}{2(2+1)^2}+\frac{1}{2(1+1)^2} \\ & +\frac{1}{2(2+1)}-\frac{1}{2(1+1)} - \frac{1}{4}\ln (2+1)+\lim_{t\rightarrow 1}\frac{1}{4}\ln (t+1) \\ = & \frac{1}{4}\ln (3)-\lim_{t\rightarrow 1}\frac{1}{4}\ln (t-1) - \frac{1}{18}+\frac{1}{8} +\frac{1}{6}-\frac{1}{4} - \frac{1}{4}\ln (3)+\lim_{t\rightarrow 1}\frac{1}{4}\ln (t+1) \\ = & -\lim_{t\rightarrow 1}\frac{1}{4}\ln (t-1) +\lim_{t\rightarrow 1}\frac{1}{4}\ln (t+1)-\frac{1}{72}
\\ = & \frac{1}{4}\lim_{t\rightarrow 1}\left (\ln (t+1)-\ln (t-1)\right )-\frac{1}{72} \\ = & \frac{1}{4}\cdot \lim_{t\rightarrow 1}\ln \frac{t+1}{t-1}-\frac{1}{72} \\ = & \frac{1}{4}\cdot \infty -\frac{1}{72} \\ = & \infty \end{align*}
So also the integral $\displaystyle{\int_1^2\frac{t\ln t}{(1-t^2)^2}\, dt}$ doesn't converge.
Therefore neither $\displaystyle{\int_0^{+\infty}\frac{t\ln t}{(1-t^2)^2}\, dt}$ converges.
As for integral #5 :
We apply the substituion $x=e^t$ ($ \Rightarrow \ln x=t$) and get \begin{equation*}\int_1^{+\infty}\frac{\left (\ln x\right )^{\beta}}{x^{\alpha}}\, dx=\int_0^{+\infty}\frac{\left (t\right )^{\beta}}{\left (e^t\right )^{\alpha}}\, e^t\, dt=\int_0^{+\infty}t^{\beta}e^{(1-\alpha)t}\, dt\end{equation*}
For $1-\alpha\geq 0 \Rightarrow \alpha \leq 1$ we have that $e^{(1-\alpha)t}\geq 1$, so we get:
\begin{equation*}\int_0^\infty t^\beta e^{(1-\alpha)t}dt\geq \int_0^\infty t^\beta dt\rightarrow +\infty\end{equation*}
Therefore also $\displaystyle{\int_1^{+\infty}\frac{\left (\ln x\right )^{\beta}}{x^{\alpha}}\, dx}$ diverges for $\beta\in \mathbb{R}$.
For $1-\alpha <0 \Rightarrow \alpha > 1$ we have that:
\begin{equation*}\int_0^{+\infty}t^{\beta}e^{(1-\alpha)t}\, dt=\int_0^1t^{\beta}e^{(1-\alpha)t}\, dt+\int_1^{+\infty}t^{\beta}e^{(1-\alpha)t}\, dt\end{equation*}
- $\displaystyle{\int_0^1t^{\beta}e^{(1-\alpha)t}\, dt\leq \int_0^1t^{\beta}\cdot 1\, dt=\int_0^1t^{\beta}\, dt=\left [\frac{t^{\beta+1}}{\beta+1}\right ]_0^1}$
If $\beta+1> 0 \Rightarrow \beta>-1$ then this is equal to $\displaystyle{\frac{1^{\beta+1}}{\beta+1}-\frac{0^{\beta+1}}{\beta+1}=\frac{1}{\beta+1}\in \mathbb{R}}$, so the intagral $\displaystyle{\int_0^1t^{\beta}\, dt}$ converges andd so also $\displaystyle{\int_0^1t^{\beta}e^{(1-\alpha)t}\, dt}$. - We have that $\displaystyle{\int_1^{+\infty}t^{\beta}e^{(1-\alpha)t}\, dt< \int_1^{+\infty}t^{\beta}\, dt=\left [\frac{t^{\beta+1}}{\beta+1}\right ]_1^{+\infty}}$.
If $\beta+1< 0 \Rightarrow \beta<-1$ then this is equal to $\displaystyle{\lim_{t\rightarrow +\infty}\frac{t^{\beta+1}}{\beta+1}-\frac{1^{\beta+1}}{\beta+1}=0-\frac{1}{\beta+1}=-\frac{1}{\beta+1}\in \mathbb{R}}$, so the integral $\displaystyle{\int_1^{+\infty}t^{\beta}\, dt}$ converges and so also also $\displaystyle{\int_1^{+\infty}t^{\beta}e^{(1-\alpha)t}\, dt}$. So we have to check the convergence of the second integral if $\beta>-1$ and the convergence of the first integral if $\beta<-1$, or not? :unsure:
FAQ: Do These Integrals Converge or Diverge?
What is the purpose of checking convergence of integrals?
Checking convergence of integrals is important because it allows us to determine if the integral of a function is finite or infinite. This is useful in many areas of mathematics and science, such as in calculating probabilities, finding areas under curves, and solving differential equations.
How do you check the convergence of an integral?
There are several methods for checking the convergence of integrals, including the comparison test, the limit comparison test, the ratio test, and the root test. These tests involve comparing the given integral to a known integral or series with known convergence properties.
What is the difference between absolute convergence and conditional convergence?
Absolute convergence refers to an integral that converges regardless of the order in which the terms are added. On the other hand, conditional convergence refers to an integral that only converges when the terms are added in a specific order. This distinction is important when using certain convergence tests, such as the ratio test.
Can an integral converge at one point and diverge at another?
Yes, it is possible for an integral to converge at one point and diverge at another. This is known as a singular point or a point of discontinuity. In these cases, it is important to carefully analyze the behavior of the function near the singular point to determine the convergence properties of the integral.
Are there any real-world applications of checking convergence of integrals?
Yes, there are many real-world applications of checking convergence of integrals. For example, in physics, integrals are used to calculate the work done by a force, the center of mass of an object, and the energy of a system. In economics, integrals are used to calculate the area under a demand or supply curve, which represents the total economic value of a product or service. In engineering, integrals are used to calculate the total force or torque on a structure or system.
