Check differentiability in function
I haven't thought about it too hard. But I still think that the problem is to show that the limit \lim_{h\to 0}\frac{h^3}{h^2+k^2} does not exist.
Sux
Hello, I can't find any way to prove if this funtion is or isn't differentiable in if [tex](x,y)=(0,0)[/tex] :
[tex]{f(x,y)=\displaystyle\frac{x^{3}}{x^{2}+y^{2}}}[/tex] if [tex](x,y) \neq(0,0)[/tex]
[tex]f(x,y)=0[/tex] if [tex](x,y)=(0,0)[/tex]
Partial derivatives don't exist in (0,0), so i have calculate definition of differentiability, and i get:
[tex]\displaystyle\lim_{x,y \to{0,0}}{} \displaystyle\frac{x^{3}}{(x^{2}+y^{2})^{3/2}}[/tex]
Which limit doesn't exit, so it is not differentiable in (0,0).
Is this right?
Thanks!
If we approach the origin along the x-axis, we find that the limit is 0. But if we approach the origin along the curve y = x^(3/2), the limit is 1. Hence the function is not continuous at the origin, which of course means it's not differentiable there.
If you were trying to apply the definition of the partial derivative to show non-differentiability at (0,0), then the approach would fail since this is an example of a function which has a directional derivative in every direction at the origin (and of course partial differentiability is the specific case where the unit vector in the definition of the directional derivative is taken to be a standard basis vector). You should demonstrate this.
That isn't correct. You may be thinking of the limit as x goes to infinity, not zero. The function is continuous at (0,0).
To the OP: Try looking at the partial fy along y = 0 and y = x.
Sorry you're right, I was thinking about infinity; the epsilon and deltas check out. Incidentally, I found an error in my untested lecture notes.
As for your hint, presumably you want to show that the partial derivative of y is not continuous at (0,0), but this doesn't guarantee non-differentiability right? The theorem that all the partial derivatives of a function exist and are continuous implies differentiability does not have a converse, as can be demonstrated via the following function:
[tex]\[ f(x,y) =\begin{cases}x^2\sin(\frac{1}{x}) + y^2 &\text{if }x \neq 0 \\
y^2 &\text{if }x = 0 \end{cases} \][/tex]
Yes, you're correct about the converse. On looking at it a bit more I think it is differentiable at (0,0). One can calculate fx(0,0) and fy(0,0) then check the condition for differentiability:
[tex]f(0+h,0+k) - f(0,0) = f_x(0,0) h + f_y(0,0)k +\varepsilon_1h + \varepsilon_2k[/tex]
where ε1 and ε2 → 0 as h and k → 0 directly by writing it out.
Sorry I said partial derivatives don't exist, I wanted to say they are not continuous in (0,0).
I have calculated [tex]f_{y}[/tex] and it is not continuous in (0,0).
How can you calculated the condition for differentiability that have written?
Thanks!
Is this right?
Thanks!
This function is both continuous and differentiable at (0,0). o But let's check these two conditions:
1- Continuity: since the numerator x3 in [tex]{f(x,y)=\displaystyle\frac{x^{3}}{x^{2}+y^{2}}}[/tex] tends to zero faster than the denominator, so [tex]\displaystyle\lim_{x,y \to{(0,0)}}{} \displaystyle\frac{x^{3}}{x^{2}+y^{2}} = 0 [/tex] and by f(0,0)=0, this condition is met by our function.
2- Differentiablity: first start with the derivative of [tex]{f(x,y)=\displaystyle\frac{x^{3}}{x^{2}+y^{2}}}[/tex] wrt x and after calculating it, find the value for [tex](x=\epsilon,y=0)[/tex]. Repeat this calculation for y and then substitute [tex](x=0,y=\epsilon)[/tex] in the result. This value must match the preceding one and of course f'(x=0,y=0) which is clearly zero from the second part of the definition of f(x,y), BUT IT DOESN'T.
[Edit]: fx([tex]\epsilon[/tex],0) = 1 so it does not match fy(0,[tex]\epsilon[/tex])=0 and therefore the function is NOT differentiable at (0,0). For a better understanding of why this condition does not hold for f, see its graph:
http://img149.imageshack.us/img149/627/plotg.jpg
Sounds like we have a cusp there.
AB
Thanks!
The first step is to calculate fx and fy at (0,0). I get that fx(0,0)=1 and fy(0,0)=0; you can check this. Then substituting everything into the equation:
[tex]
[/tex]
gives:
[tex]\frac {h^3}{h^2+k^2} = 1h + 0k + \varepsilon_1h + \varepsilon_2k[/tex]
Solve this for the epsilon terms:
[tex]\varepsilon_1h + \varepsilon_2k = \frac {h^3}{h^2+k^2} -h= \frac{hk^2}{h^2+k^2}= 0h+\left(\frac{hk}{h^2+k^2}\right)k[/tex]
That will do it if you can show
[tex]lim_{(h,k)\rightarrow(0,0)}\frac{hk}{h^2+k^2} = 0[/tex]
Can you take it from there?
[Edit] And then again, maybe that doesn't go to zero :frown:
FAQ: Check differentiability in function
What is the definition of differentiability in a function?
Differentiability is a mathematical concept that describes how smooth a function is. A function is said to be differentiable if it has a well-defined derivative at every point within its domain.
How do you check for differentiability in a function?
To check for differentiability in a function, you can use the definition of differentiability which states that a function is differentiable if the derivative exists at every point within its domain. This can be checked by calculating the derivative using limit definition or using differentiation rules.
What are the necessary conditions for a function to be differentiable?
In order for a function to be differentiable, it must satisfy the following conditions:
1. The function must be continuous at every point within its domain.
2. The function must have a well-defined derivative at every point within its domain.
3. The derivative must exist and be finite at every point within its domain.
Can a function be differentiable at some points and not at others?
Yes, it is possible for a function to be differentiable at some points and not at others. This is because the function may satisfy the necessary conditions for differentiability at some points, but fail to do so at others.
Are there any functions that are not differentiable?
Yes, there are some functions that are not differentiable. These include functions with discontinuities, corners, or cusps, as well as functions with vertical tangents or infinite slopes at certain points within their domain.
