Check if the function is odd or even
In summary, the conversation discusses the properties of odd functions and how to check if a function is odd. It also mentions that most functions are neither even nor odd.
transgalactic
1,395
i know that if f(x)=f(-x) and if f(-x)=-f(x) then its odd.
i tried to do this check on this cases
but its not working
http://img126.imageshack.us/img126/3942/74448798fv8.gif
These questions aren't always straight forward, you need to understand how the functions behave. Let's consider the first case:
So you have
[tex]f\left(-x\right) = \log\left(\frac{1+x}{1-x}\right) = \log\left(\frac{1-x}{1+x}\right)^{-1} = - \log\left(\frac{1-x}{1+x}\right) = -f\left(x\right)[/tex]
Do you follow?
And, of course, most functions are neither even nor odd.
thanks
FAQ: Check if the function is odd or even
What is an odd function?
An odd function is a function that satisfies the condition f(-x) = -f(x) for all values of x. In other words, the function has symmetry about the origin (0,0) and its graph is a reflection across the origin.
What is an even function?
An even function is a function that satisfies the condition f(-x) = f(x) for all values of x. In other words, the function has symmetry about the y-axis and its graph is a reflection across the y-axis.
How do you check if a function is odd?
To check if a function is odd, you can use the property f(-x) = -f(x). Plug in -x for x in the function and simplify. If the result is equal to -f(x), then the function is odd.
How do you check if a function is even?
To check if a function is even, you can use the property f(-x) = f(x). Plug in -x for x in the function and simplify. If the result is equal to f(x), then the function is even.
Can a function be both odd and even?
No, a function cannot be both odd and even. A function can only have one type of symmetry, either odd or even. If the function satisfies both conditions, then it is neither odd nor even.
