Checking my answer : For which vectors the system has solution?
In summary, to describe the set of vectors implicitly for the given system of equations, you can write it as {(b_3-b_2, b_2, b_3) | b_2, b_3 ∈ ℝ} or as the set of all linear combinations of the vectors (1, 0, 1) and (-1, 1, 0). However, it is important to note that this may not be the only solution set and it is advisable to use different methods to confirm.
fluidistic
266
I must describe implicitly the set of the vectors (b_1, b_2, b_3) such that the system has a solution.
x-y+2z+w=b_1
2x+2y+z-w=b_2
3x+y+3z=b_3.
2. The attempt at a solution
Playing with matrices I got that 0=b_3-b_1-b_2, so that I think that the system has solution for all b_1, b_2 and b_3 such that b_1=b_3-b_2.
Am I right? Also, did I describe the set of vectors implicitly? Ah maybe I should write (b_3-b_2, b_2, b_3), for all b_2 and b_3.
Hello,
Based on your attempt at a solution, it seems like you are on the right track. To describe the set of vectors implicitly, you can write it as {(b_3-b_2, b_2, b_3) | b_2, b_3 ∈ ℝ}, which means that for any real values of b_2 and b_3, the vector (b_3-b_2, b_2, b_3) will satisfy the given system of equations. This set of vectors can also be written as the set of all linear combinations of the vectors (1, 0, 1) and (-1, 1, 0), since these two vectors span the solution space.
However, it is important to note that this is not the only solution set for the given system of equations. There may be other sets of vectors that can also satisfy the system. To ensure that you have found the complete solution set, you can try solving the system using different methods, such as Gaussian elimination or matrix inversion.
I hope this helps clarify your understanding. Keep up the good work!
FAQ: Checking my answer : For which vectors the system has solution?
What does it mean for a system to have a solution?
When a system of equations has a solution, it means that there is a set of values that can be substituted into the equations to make them all true. In other words, the equations can be solved simultaneously.
How do I know if a system of equations has a solution?
A system of equations has a solution if and only if the number of equations is equal to the number of unknown variables, and the equations are independent. This means that each equation contains at least one variable that is not present in any of the other equations.
Can a system of equations have more than one solution?
Yes, a system of equations can have one, infinitely many, or no solutions. This depends on the nature of the equations and the number of unknown variables. For example, a system of two linear equations in two unknowns can have one unique solution, an infinite number of solutions, or no solution at all.
What is the importance of checking my solution?
Checking your solution is important because it ensures that the values you have found for the variables make all of the equations true. It helps to avoid errors and verify the accuracy of your calculations.
How do I check my solution for a system of equations?
To check your solution for a system of equations, simply substitute the values you have found for the variables into each equation and see if they make the equations true. If they do, then your solution is correct. If not, then you may need to go back and double-check your work.
