Checking the Lorentz transformation
In summary, the conversation discusses the problem of relativity of simultaneity when using time dilation formulas for different frames of reference. It also suggests considering the movement of frame B to the left relative to frame C as an alternative approach.
QipshaqUli
This seemed at first glance very easy. But there appeared some confusion.
A is moving to the right with velocity v with respect to B. The proper time for A is ##t_a=t_b\sqrt{1-v^2/c^2}##. And B is moving to the right with velocity u with respect to C. Proper time for B ##t_b=t_c\sqrt{1-u^2/c^2}##. ##t_a## can be found by ##t_c## then: ##t_a=t_c\sqrt{1-u^2/c^2}\sqrt{1-v^2/c^2}## then. Futher, by using the law of addition of relativistic velocities one can find the relative velocity of A with respect to C: ##w=\frac{u+v}{1+\frac{uv}{c^2}}##. And defining proper time for A by ##w## I found ##t_a=t_c\frac{\sqrt{1-u^2/c^2}\sqrt{1-v^2/c^2}}{1+\frac{uv}{c^2}}## which is different from previous one.
$$t_a=t_c\frac{\sqrt{1-u^2/c^2}\sqrt{1-v^2/c^2}}{1+\frac{uv}{c^2}}$$
Homework Statement: This seemed at first glance very easy. But there appeared some confusion.
Homework Equations: $$t_a=t_c\frac{\sqrt{1-u^2/c^2}\sqrt{1-v^2/c^2}}{1+\frac{uv}{c^2}}$$
[Note from mentor: please see https://www.physicsforums.com/help/latexhelp/ for the proper delimiters for LaTeX code on this forum. I have edited your post accordingly, in order to make your equations properly visible.]
You have a problem with the relativity of simultaneity. When you use the time dilation formula for B relative to A you are using the simultaneity of A. Similarly, when you use the time dilation formula for C relative to B you are using the simultaneity in the rest frame of B. Thus, the combination will not correspond to the time dilation of C relative to A, which exclusively is based on simultaneity as defined by A.
Likes Abhishek11235
Instead, why not have ##B## moving to the left relative to ##C##? The same formulas apply, but now frame ##A## and ##C## are the same frame, yet you have their clocks time dilated relative to each other.
Related to Checking the Lorentz transformation
1. What is the Lorentz transformation?
The Lorentz transformation is a mathematical formula used to describe how measurements of space and time are affected by objects moving at high speeds, as predicted by Einstein's theory of special relativity.
2. Why is it important to check the Lorentz transformation?
It is important to check the Lorentz transformation because it is a fundamental element of the special theory of relativity, which has been experimentally verified numerous times. By checking the transformation, scientists can ensure that their measurements and calculations are accurate and in line with the principles of relativity.
3. How is the Lorentz transformation derived?
The Lorentz transformation is derived from the principle of relativity, the concept that the laws of physics should be the same for all observers in uniform motion. It is also based on the speed of light being constant for all observers.
4. Can the Lorentz transformation be applied to any speed?
No, the Lorentz transformation is only applicable to objects moving at high speeds close to the speed of light. At lower speeds, the laws of classical mechanics can accurately describe the behavior of objects.
5. Are there any experimental tests for the Lorentz transformation?
Yes, there have been numerous experimental tests conducted to verify the predictions of the Lorentz transformation. One famous example is the Michelson-Morley experiment, which aimed to detect the hypothetical ether medium through which light was thought to travel. The results of this experiment supported the principles of relativity and the validity of the Lorentz transformation.
