Chemical composition of relativistic neutron star jets?
In summary: Interesting link which illustrates the reason for my post. A neutron star or stellar black hole is only the size of an asteroid and hence can’t be resolved at hundreds of light years. The only features that can be seen/resolved are the jets and accretion, and glows from the surface. Analysis of the glows is very difficult. The mystery of neutron star relativistic jets is probably easier to understand than stellar back hole jets so neutron star observations could provide the answers for both.Spectral analysis should reveal the chemical composition of the jets and the accretion. If they are different where does the change occur? Also the synchronization of the jets and accretion is easily observed, and if they are not
Bernie G
330
Is there any good information about the chemical composition of relativistic jets from neutron stars? If the chemical composition of the jets was different from the accretion material it could shed light on the process that forms the jets.
Astronomy news on Phys.org
davenn said:
whilst not exactly what you are after, it may give you some enlightenment on the subject
http://arxiv.org/pdf/astro-ph/0305435v1.pdf Dave
Spectral analysis should reveal the chemical composition of the jets and the accretion. If they are different where does the change occur? Also the synchronization of the jets and accretion is easily observed, and if they are not synchronized it means a lot. The type of info I seek is like that in the following 2 links ….. where could the iron come from? Iron is what could be expected on the surface of a neutron star:
http://www.esa.int/Our_Activities/Space_Science/Black_hole_boasts_heavyweight_jets
http://www.astronomy.com/news/2015/08/neutron-stars-strike-back-at-black-holes-in-jet-contest
If the chemical composition of ultra relativistic jets was electrons and positrons, would it be possible for the disintegration of neutrons to produce this directly?
This is what I posted on another question, and think its relevant here:
IMHO if a jet has a velocity >0.9c it should be composed mostly of tiny particles like electrons, positrons, neutrinos, quarks, other leptons, etc. If full size atoms are present in a >0.9c jet they are probably small in quantity and just going along for the ride.
This would violate baryon number conservation.
At the energies needed to accelerate particles to 0.9 c, atoms will rarely keep all their electrons, they are just stripped too easily. You still get protons and other nuclei.
Yes, but do >0.9c jets have a representative number of protons or other nuclei? If so almost all the mass in the jet would be nuclei. It would be amazing to have a significant number of protons moving at 0.999c although it might not be so amazing to have occasional protons carried along in a 0.999 jet of lepton like particles.
Cosmic rays are mainly protons and a few other nuclei - with energies up to 1020 eV, or 0.9999999999999999999999999999999 c (iron at 1020 eV, digits counted). What is 0.999c compared to that?
Here are nuclei in jets
Amazing stuff, supernovae explosions squirting lots of nuclei. That link on jet composition isn't clear if there are a trace amounts or a lot of nuclei in that jet or if its mostly leptons. It would be good to know if >0.9c jets from neutron stars are mostly leptons and/or if they have a lot nuclei. That might shed some light on how can a neutron star produce >0.9c jets and where do the leptons come from?
Well, my link goes to the description for the public, the actual publication will have more details (and also references to previous work done).
I'm not knocking it, its a good link, thanks. Note the jet speed in that link is 0.66c. It would be amazing if most of the mass in a >0.9c jet were nuclei.
If the jets near the accretion disc maintain a positive charge, eventually free electrons are going to be accelerated from the galaxy toward the charged jets. At perhaps some great distance they will recombine with it.
But I don't see how the base of the jets could initially have an overall neutral charge. The accretion disc must be embedded in a powerfully confining magnetic field that turns particles according to charge and mass.
Related to Chemical composition of relativistic neutron star jets?
1. What is the chemical composition of relativistic neutron star jets?
The chemical composition of relativistic neutron star jets is primarily made up of ionized hydrogen and helium, along with smaller amounts of heavier elements such as iron and nickel. This composition is similar to that of other astrophysical jets.
2. How are the chemical elements in relativistic neutron star jets formed?
The chemical elements in relativistic neutron star jets are formed through nuclear fusion processes in the hot, dense environment of the neutron star. This fusion occurs due to the extreme temperatures and pressures in the core of the neutron star, which can reach up to 10 billion degrees Celsius.
3. What role do magnetic fields play in the chemical composition of relativistic neutron star jets?
Magnetic fields are thought to play a crucial role in shaping and accelerating relativistic neutron star jets. These fields can influence the direction and speed of the jets, as well as the composition of the material being ejected.
4. How does the chemical composition of relativistic neutron star jets affect their behavior and evolution?
The chemical composition of relativistic neutron star jets can greatly impact their behavior and evolution. For example, the presence of heavier elements can make the jets more unstable and prone to fragmentation, while the composition can also affect the jet's interaction with its surroundings and the production of radiation.
5. Can the chemical composition of relativistic neutron star jets provide insights into the formation and evolution of neutron stars?
Yes, studying the chemical composition of relativistic neutron star jets can provide valuable insights into the formation and evolution of these extreme objects. By analyzing the elements present in the jets, scientists can learn more about the processes that occur in the core of the neutron star and how it evolves over time.
  • Astronomy and Astrophysics
