How Much Natural Gas Is Needed to Produce One Tonne of Ammonia?
In summary, the Haber process is used to produce ammonia (NH3) by combining nitrogen (N2) and hydrogen (H2). The nitrogen is obtained from air by burning natural gas (CH4), while the hydrogen is obtained by steam reforming natural gas and then using a shift conversion reaction. To determine the amount of natural gas needed to produce one tonne of ammonia, the moles of ammonia and hydrogen must be calculated, and then the moles of natural gas can be determined using the stoichiometry of methane.
ABR124
Ammonia NH3 is made by the haber process: N2 + 3H2 --> 2NH3
The nitrogen required for this process is obtained from air by using the air to burn natural gas CH4 , thereby removing the oxygen from the air, leaving behind only nitrogen. The hydrogen required is obtained by steam reforming natural gas to carbon monoxide and hydrogen, followed by a shift conversion reaction to increase the yeild of hydrogen:
CH4(g) + H2O(g) --> CO(g) + 3H2(g) Steam Reforming
CO(g) + H2O(g) --> CO2(g) + H2(g) Shift Conversion
How many cubic meters of natural gas at STP is required to produce one tonne of ammonia? Air may be assumed to consist of 80% mol nitrogen and 20 % mol oxygen. For the purpose of calculation, you may assume the complete stoichometric of methane in air to produce carbon dioxide and water and that no nitrogen oxides are formed.
Not to sure
Don't know where to start with this one, I just want to get on the right track
Determine how many moles of ammonia are in one ton
Then: moles NH3 (3H2/2NH3) = moles H2 required.
Determine how many moles of CH4 are contained in 1 M3
Note that 1 mole of CH4 yields 4 moles H2
And 22.4 liters at STP contains 1 mole of gas
Related to How Much Natural Gas Is Needed to Produce One Tonne of Ammonia?
1. What is a Chemical Engineer Ammonia Problem?
A Chemical Engineer Ammonia Problem refers to a specific issue or challenge related to the production, transportation, storage, or use of ammonia in an industrial setting. This can include problems with equipment, processes, or safety concerns.
2. What are the potential hazards associated with ammonia in chemical engineering?
Ammonia is a highly toxic and corrosive chemical that can cause serious health hazards if not handled properly. Exposure to ammonia can result in skin and respiratory irritation, chemical burns, and even death. It is important for chemical engineers to follow strict safety protocols when working with ammonia.
3. How do chemical engineers solve ammonia problems?
Chemical engineers use their knowledge of chemistry, physics, and engineering principles to design and implement solutions for ammonia problems. This may involve troubleshooting equipment, optimizing processes, conducting experiments, or implementing safety measures.
4. What industries rely on ammonia and may encounter ammonia problems?
Ammonia is a key ingredient in the production of fertilizers, as well as being used in refrigeration, cleaning products, and various industrial processes. Therefore, industries such as agriculture, food processing, and chemical manufacturing may encounter ammonia problems.
5. How can ammonia problems be prevented?
Preventing ammonia problems requires a combination of proper training, strict adherence to safety protocols, and regular maintenance of equipment. Chemical engineers also play a crucial role in identifying potential problems and implementing preventative measures to avoid them in the future.
  • Mechanical Engineering
  • Thermodynamics
