Chemical Equilibrium Characteristics
In summary: In this case, the statement is true. The amounts of CO in the two vessels, at equilibrium, will be the same since they are in equal volumes and the reaction is reversible. Sorry for the confusion.
salman213
302
Consider the reaction:
H2O(g) + CO(g) H2(g) + CO2(g)
Which of the following statements are true and which are false.
false Reactions with large equilibrium constants are always slow.
false
When Q > K the system will spontaneously shift to the right.
false Amounts of all reactants and products corresponding to an exact equilibrium composition for this reaction are sealed in a vessel. The CO placed in the vessel is labelled with 14C. After an indefinite period of time 14C would still be found only in the CO molecules and not in CO2.
false 1 mol of H2O(g) and 1 mol of CO(g) are placed in a vessel and 1 mol of H2(g) and 1 mol of CO2(g) are placed in another of equal volume. At equilibrium, at 350°C, the amounts of CO(g) in the two vessels are equilvalent.
true At equilibrium, the overall composition of the reaction mixture is not changing.
false At equilibrium, individual molecules cannot undergo any chemical reactions.
HI can someone chek those for me, there is/are some wrong answer there but i cannot seem to figure it out. If someone can see it please help!
Chemistry news on Phys.org
anyone mind quickly looking at this please?
I don't know what Q and K mean, but the rest of the answers look about right.
You might want to rethink the fourth answer.
"false 1 mol of H2O(g) and 1 mol of CO(g) are placed in a vessel and 1 mol of H2(g) and 1 mol of CO2(g) are placed in another of equal volume. At equilibrium, at 350°C, the amounts of CO(g) in the two vessels are equilvalent."
The amounts of CO in the two vessels, at equilibrium, will only be the same if the equation states that the amount of products and reactants are the same, which would be K=1. Unless K is 1, this statement is false.
You must assume that the reaction is completely reversible to obtain an equilibrium mixture. The initial state is unimportant. The amounts of material (C, H and O) are important and are equal in both of these cases.
This is not true.
My mistake. I assumed the reaction was not reversible.
FAQ: Chemical Equilibrium Characteristics
What is chemical equilibrium?
Chemical equilibrium is a state in a chemical reaction where the rates of the forward and reverse reactions are equal, resulting in no net change in the concentrations of reactants and products.
How is chemical equilibrium achieved?
Chemical equilibrium is achieved when the concentrations of reactants and products reach a steady state and the rates of the forward and reverse reactions are equal. This can happen when a reaction is allowed to proceed in a closed system or when the reactants are continuously added to the reaction mixture.
What factors affect chemical equilibrium?
The factors that affect chemical equilibrium include temperature, pressure, and the initial concentrations of reactants and products. Changes in these factors can shift the equilibrium position, resulting in changes in the concentrations of reactants and products.
How can chemical equilibrium be altered?
Chemical equilibrium can be altered by changing the conditions of the reaction, such as temperature, pressure, or concentrations of reactants and products. This can shift the equilibrium position and change the concentrations of reactants and products.
What is Le Chatelier's Principle?
Le Chatelier's Principle states that when a system at equilibrium is subjected to a change, it will respond by shifting in a direction that minimizes the effect of the change. This means that changes in temperature, pressure, or concentrations of reactants and products can cause the equilibrium position to shift in order to maintain the balance between the forward and reverse reactions.
