Chemical PCP found in older Electrical Transformers
In summary, last summer, the conversation was about taking inventory of transformers for the Public Utilities company. The focus was on identifying transformers containing PCB, a now banned toxic chemical used as a flame resistant heat transfer compound. The purpose of this chemical in transformers was to prevent fires. However, due to its harmful effects on health and the environment, PCB-containing transformers are being replaced with newer models that use different, safer fluids for cooling. For more information on the specific fluids used and the history of transformer oils, refer to the provided sources.
Seth Vogt
I worked for the Public Utilities company last summer, and we were tasked with taking inventory around the entire city, of all the transformers. We wrote down as much info as we could about the transformers, including Serial Number and whether or not it contained PCP's. From what I understood, the PCP-containing transformers would be replaced with non-PCP transformers. What is this PCP chemical? Is it dangerous? What purpose did it serve in the transformer if it could replaced with the non-PCP transformers? I want to know more about this information so I can effectively communicate exactly what we were doing last summer in a job interview if anyone asks. Thanks so much for any information!
Chemistry news on Phys.org
First: PCB. Not PCP. Stands for polychlorinated biphenyl. A flame resistant heat transfer compound.
Thank you for the clarification! So this "flame resistant heat transfer compound" isn't necessary in newer models then? Why were they replacing the PCB-containing transformers?
Because the PCB material was toxic and stayed in the ground and water when released, and it accumulated in plant and animal tissues, causing certain deleterious effects on health.
PCBs are now banned.
This article gives a good discussion of fluids used to cool transformers then and now:
http://apps.geindustrial.com/publibrary/checkout/Dielectric?TNR=White Papers|Dielectric|generic
For more general info:
https://en.wikipedia.org/wiki/Transformer_oil
Related to Chemical PCP found in older Electrical Transformers
1. What is chemical PCP and where is it commonly found?
Chemical PCP, or pentachlorophenol, is a synthetic organic compound that is commonly used as a pesticide and fungicide. It was also used as a wood preservative and can be found in older electrical transformers.
2. How does chemical PCP affect the environment?
Chemical PCP is considered a persistent organic pollutant and can have harmful effects on the environment. It can contaminate soil and water, and can also bioaccumulate in animals and plants.
3. What are the health effects of exposure to chemical PCP?
Exposure to chemical PCP can cause a variety of health effects, including skin irritation, respiratory problems, and neurological effects. It is also considered a probable human carcinogen.
4. Is there a safe level of exposure to chemical PCP?
The EPA has set a maximum contaminant level of 0.4 parts per billion (ppb) for chemical PCP in drinking water. However, any level of exposure can potentially have negative health effects, so it is important to limit exposure as much as possible.
5. How can we prevent exposure to chemical PCP?
The best way to prevent exposure to chemical PCP is to avoid contact with products that contain it, such as older electrical transformers. If you suspect you may have been exposed, seek medical attention and follow proper safety precautions, such as wearing protective gear and washing thoroughly after contact.
