Chemical potential and fugacity
The discussion centers on the definition and equivalence of chemical potential and fugacity in statistical physics. The author explores how chemical potential is defined in both Maxwell-Boltzmann and quantum statistics, highlighting the confusion arising from its dual presentation. They clarify that chemical potential should be defined in the context of the Grand Canonical Ensemble, where particle number can vary, leading to the relation μ = (∂U/∂N)_{S,V}. The author successfully derives the relationship between chemical potential and fugacity, showing that α = -μ/kT and β = 1/kT, thus proving the equivalence. This exploration emphasizes the importance of a unified definition of chemical potential in thermodynamic equations.
Kaguro
I am trying to learn statistical physics. While learning MB statistics, my textbook defined chemical potential as ##\mu = (\frac{\partial F}{\partial N})_{V,T}##. That's nice.
Later when I started on Quantum statistics, my textbook described all three distribution functions via:
##n_i = \frac{g_i}{e^{\alpha + \beta E_i} + \kappa}##
We had already found out the value of beta from MB statistics (using MB distr. function. Why would that apply here is another mystery altogether)
Then suddenly book said:
##n_i = \frac{g_i}{e^{\frac{E_i - \mu}{K_B T}} + \kappa}##
Where we define chemical potential via the relation ##\alpha = -\mu/kT## (and its exponential is called fugacity)
How and why did the book define the same thing twice!?
To all future people who want to know: I found out how can we show equivalence.
We need to define mu only once, but neither in these places. We need to define mu in the fundamental thermodynamic equation:
First consider Grand Canonical Ensemble, that is, allow particle number to change.
Generalise first and second laws into this:
##dU = TdS - PdV + \mu dN##
We define ##\mu## as the rate of change of energy per unit change in particle number.
Then from this relation, ##\mu = (\frac{\partial U}{\partial N})_{S,V}##
F = U-TS
So, ##dF=-PdV - SdT + \mu dN##
##\Rightarrow \mu = (\frac{\partial F}{\partial N})_{T,V}## (Yaay!)
Now while deriving the distribution function by maximizing the log of number of microstates and using method of Lagrange multipliers we got:
##d(lnW) = \alpha dN + \beta dE##
So, ##\alpha = (\frac{\partial ln(W)}{\partial N})_{E,V}##
But we know ##S=k_B ln(W)## (separate derivation for that. But it is standalone)
##\Rightarrow lnW = \frac{S}{k_B}##
##\Rightarrow \alpha = \frac{1}{k_B} (\frac{\partial S}{\partial N})_{E,V}##
Now, ##TdS=dU+PdV-\mu dN##
##(\frac{\partial S}{\partial N})_{U,V} = \frac{-\mu}{T}##
Therefore, ##\alpha = \frac{-\mu}{kT}## (Yaaaay!)
Similarly we can show that ##\beta = \frac{1}{kT}##
Hence Proved.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
