Chemistry colution prep question (quick)
  • Thread starter vande060
  • Tags
    Chemistry
In summary, a solution in chemistry is a homogeneous mixture composed of two or more substances, with the main component being the solvent and the other components being solutes. To prepare a solution, the appropriate amount of solute must be dissolved in a specific amount of solvent, depending on the desired concentration. A concentrated solution has a high amount of solute while a dilute solution has a low amount. The concentration of a solution is calculated by dividing the moles of solute by the volume of solution in liters. Common mistakes to avoid when preparing a solution include inaccurate measurements, not properly dissolving the solute, and not considering the total volume of the solution.
vande060
186
I have to dissolve phenylthiourea in a phosphate buffer solution. The final molarity of the phenylthiourea is 10^-5, but it says to dissolve it in ethanol. Does this mean that I have to dissolve my weight of phenylthiourea in a minimal amount of ethanol, then bring that to volume with the phosphate buffer?
That's what I would try.
FAQ: Chemistry colution prep question (quick)
What is a solution in chemistry?
A solution in chemistry is a homogeneous mixture composed of two or more substances. The main component of a solution is called the solvent, while the other components are called solutes. Solutions can be in the form of liquids, gases, or solids.
How do I prepare a solution in chemistry?
To prepare a solution in chemistry, you will need to measure out the appropriate amount of solute and dissolve it in a specific amount of solvent. The amount of solute and solvent needed will depend on the desired concentration of the solution. It is important to follow the proper steps and use accurate measurements to ensure the solution is prepared correctly.
What is the difference between a concentrated and a dilute solution?
A concentrated solution has a high amount of solute dissolved in a given amount of solvent, while a dilute solution has a low amount of solute dissolved in the same amount of solvent. This means that a concentrated solution is more potent and has a higher concentration of particles compared to a dilute solution.
How do I calculate the concentration of a solution?
The concentration of a solution is typically measured in molarity (M) and is calculated by dividing the moles of solute by the volume of solution in liters. It is important to note that the volume used in the calculation should only include the solvent, not any additional substances that may be present in the solution.
What are some common mistakes to avoid when preparing a solution?
Some common mistakes to avoid when preparing a solution include using inaccurate measurements, not properly dissolving the solute, and not considering the total volume of the solution (including the volume of the solute). It is also important to use the proper units and to carefully follow the steps outlined in the solution preparation procedure.
