Chemist125
- 16
I love computer programming, but I'm currently on a BSc Chemistry degree. Is there anyway I can combine these for a job/career?
Chemist125 said:I love computer programming, but I'm currently on a BSc Chemistry degree. Is there anyway I can combine these for a job/career?
symbolipoint said:Are you kidding? EASILY those can be combined! The subject of Chemistry is overly flooded with opportunities to create computer programs. You'll do yourself a great amount of good if you learn and use programming skills toward Chemistry.
chiro said:I think you'll have more opportunity than you realize.
There are an abundance of programmers, but very few have domain knowledge of chemistry.
I guess an obvious way is to be in charge of writing the code and the platform for simulation. There would be standalone packages that may do this, but I'm sure that there will always be cases where you have to write custom code that's very specific, and thus extend the platform in some way.
Also companies that write simulation/visualization or computational software in the domain of chemistry (or as an above posted said: computational chemistry) would look for people like yourself who have training in chemistry.
Bottom line, I think you have good options with the choices you are proposing to make.
Chemist125 said:My dream is to be able to work remotely, from home. Do you think it's a possible reality?
What should I do when I graduate with by BSc Chemistry (with industry experience)...should I try to gain formal qualifications in programming?chiro said:I think you'll have more opportunity than you realize.
Chemist125 said:What should I do when I graduate with by BSc Chemistry (with industry experience)...should I try to gain formal qualifications in programming?
There's so many possibilities...
I could try for a PhD or Masters, or even a job!
symbolipoint said:That would be waiting far too long. Learning to write computer programs needs to start before the end of the second year of your B.Sc. program. Sooner is better, so you have the chance to write some useful or interesting programs while you are still studying for your undergraduate Chemistry degree.
One important possibility is computer interfacing. You cannot practically design those kinds of programs just working remotely; you must be able to work with the end-users and observe the results directly, and look for editing changes to adjust with the program directly in place, and then work with the end user to retest. You need to be on-site for these things.
Chemist125 said:I graduate this year! When I graduate I will be 22 years old. I've already spent a year working in the chemical industry as a chemist!
I thinking that a PhD would be the best route for me...only 3 years, + I get paid.
What you think?
chiro said:You would need at least two or three years before you could move into a junior role, and those years would be jam-packed with a lot of practical project experience.
Basically you have the following areas that you learn in programming:
1) Procedural Programming Concepts
2) Domain specific Concepts
3) Computer Science Concepts
4) Engineering Concepts (specific to software)
5) Other stuff that no one talks about but that experts are aware of
With domain specific concepts you have to have some kind of understanding of the domain for domain specific concepts, but before that you need to understand how computers actually work.
If you have a good enough background in the basics, learning domain specific things is not relatively hard. If you want to be a programmer you need to demonstrate that you know these basics well enough to be able to work with say an external software library, or extend existing repositories, or to get something done quick with a lot of different code sets like say a combination of libraries and an existing repository.
Its kind of like asking a physicist to figure something out without a knowledge of math: you know its going to end up a disaster. A physicist uses experimental data and assumptions to build the math. Like the physicist a network programmer will apply network specific concepts in programming, but obviously they have to have a good base already to actually do anything useful.
You could do a PhD program that involves significant amounts of programming and if you can get something like this I would recommend it.
I would also work on some projects of your own to build up your understanding and make the connections between things that make you a solid programmer.
I guess its like any profession really, the more you discover, get your feet wet, learn every crevice and what it means, then you're bound to become good if you put in enough effort.
I think one thing you have to be aware of is that in most jobs, you're going to be expected to solve non-trivial problems more seamlessly than you realize.
I would compare the above to driving on a racetrack: if you are just learning to drive you are focusing on things like changing gears, steering, and coordinating everything which distracts from the more high level view of say an experienced driver which will be analyzing corners, acceleration and deceleration and more "high level" things that is involved in racing.
When you go into a job you will be learning to "race" instead of learning to drive, because its expected that you already have enough skill to drive without really thinking too hard about it.
They don't even want to be in Canada and you put them in the States?!Chemist125 said:Here's an example of a job I found in the states:
http://www.ccl.net/cca/jobs/joblist/mess0019765.shtml
Ryker said:They don't even want to be in Canada and you put them in the States?!
The connection between chemistry and computer programming lies in the use of computers to model and simulate chemical reactions and processes. Computer programs are also used to analyze and interpret data obtained from chemical experiments.
Computer programming can be applied in chemistry in various ways, such as designing and running simulations to study chemical reactions, creating databases to store and analyze chemical data, and developing algorithms to predict properties of chemical compounds.
The most commonly used programming languages in chemistry are Python, Java, and C++. Python is popular for its simplicity and versatility, while Java and C++ are used for their speed and ability to handle complex calculations.
Using computer programming in chemistry allows for faster and more accurate calculations, data analysis, and simulations. It also enables the creation of databases and models that can aid in understanding and predicting chemical phenomena.
While having a strong background in both chemistry and computer programming can be beneficial, it is not always necessary to be an expert in both fields to work in this area. Many scientists collaborate with programmers to develop and use computer programs in their research.
