Chemistry Help (on behalf of someone else)
  • Thread starter rizwaan
  • Tags
    Chemistry
In summary: I used Hess's law and flipped the first equation and got -729.8 kcal and multiplied the second one by 6 to get 566.4 and added everything to get -26.6 kcal.
rizwaan
1) CaF2 is added to a 0.1 M Ca(NO3)2 solution. At what concentration of F- will CaF2 begin to precipitate? Ksp of CaF2 is 4e-11??
2) The solubility of CaF2 (ksp = 4 e-11) in a 0.1 M solution of Ca(NO3)2 is approximately?
Need help finding the solutions for these. I'm posting this for someone else actually who's not that good with using forums. Please be as detailed as you can.
thank you very much in your advance for your help!
You were told at chemical forums that nobody is going to do the question for you. You will do better service to your friend showing her/him how to use forums so that we can guide her/him through the question.
Hi I'm very sorry but I copied and pasted the wrong info.
This one has more of an explanation. Let me know if you need anymore info with this.
1) Given the reactions and thermodynamic data below, calculate the enthalphy of formation for C6H5OH kcal/mol.
(kcal)
C6H5OH + 7 O2 --> 6 CO 2 + 3 H2O 729.8
C + O2 ---> CO2 -94.4
2 H2 = O2 ---> 136.8
But this is not the right answer...apparently is +41.7?
2)
The balanced equation below is for a nonsponstaneous reaction (enthalpy of formation = 131 kj/mol and
entropy of formation = 134 J/(mol x k) ). Assuming that the change in enthalpy and entropy do not vary with temperature, at what temperature will the reaction become spontaneous?
C(s) + H2O(l) --->CO(g) + H2(g)
To solve this I used delat G = delta H - T(delta S).
I got 978 K and subtracted it by 273 to get 704 C. However the answer is 1022 C?
Thank you very much for your help.
And you have ignored third equation? Show what you got (what reaction equation) after doing what you wrote you did.
1) To determine the concentration of F- at which CaF2 will begin to precipitate, we need to use the solubility product constant (Ksp) of CaF2. Ksp is the equilibrium constant for the dissolution of a sparingly soluble salt, and it is defined as the product of the concentrations of the ions raised to the power of their respective stoichiometric coefficients in the balanced chemical equation. In this case, the balanced equation for the dissolution of CaF2 is CaF2 (s) ⇌ Ca2+ (aq) + 2F- (aq). Therefore, the Ksp expression for CaF2 is Ksp = [Ca2+][F-]^2.
To determine the concentration of F- at which CaF2 will begin to precipitate, we need to set up an ICE (initial, change, equilibrium) table and use the Ksp expression to calculate the equilibrium concentration of F-. The initial concentration of Ca2+ is 0.1 M, and since CaF2 is a strong electrolyte, it dissociates completely into Ca2+ and F-. Therefore, the initial concentration of F- is also 0.1 M.
ICE Table:
I 0 M 0.1 M 0.1 M
C -x +x +2x
E 0 M (0.1+x) M (0.1+2x) M
Using the Ksp expression, we can set up the equilibrium expression as Ksp = (0.1+2x)(x)^2 = 4e-11. Solving for x, we get x = 6.32e-6 M. This means that at a concentration of 6.32e-6 M F-, CaF2 will begin to precipitate.
2) To determine the solubility of CaF2 in a 0.1 M solution of Ca(NO3)2, we need to use the same approach as above. Since Ca(NO3)2 is a strong electrolyte, it dissociates completely into Ca2+ and 2NO3-. Therefore, the initial concentration of Ca2+ is 0.1 M and the initial concentration of F- is 2(0.1) = 0.2 M.
ICE Table:
CaF
FAQ: Chemistry Help (on behalf of someone else)
What is the purpose of chemistry?
Chemistry is the scientific study of matter, its properties, and its transformations. Its main goal is to understand how substances interact and react with each other, as well as how to manipulate these interactions for practical purposes.
How can chemistry help in everyday life?
Chemistry plays a crucial role in our everyday lives. It helps us understand how food is digested, how medicines work, and how household products like cleaners and detergents are made. It also contributes to advancements in technology, such as new materials, energy sources, and medical treatments.
Can chemistry help with environmental issues?
Yes, chemistry can play a significant role in addressing environmental issues such as pollution, climate change, and resource depletion. Chemists can develop and implement sustainable solutions, such as alternative energy sources and biodegradable materials, to reduce the negative impact of human activities on the environment.
How can chemistry help with solving crimes?
Forensic chemistry is a field that uses chemical analysis to help solve crimes. It involves techniques such as DNA profiling, fingerprint analysis, and chemical residue analysis, which can provide valuable evidence in criminal investigations.
Is chemistry a difficult subject to learn?
Chemistry can be challenging, but with proper instruction, practice, and dedication, it can be a fascinating and rewarding subject to learn. It helps to have a strong foundation in math and a curious mind to understand and apply the fundamental principles of chemistry.
