Chemistry: Hot-Air Ballon Oxygen Storage
In summary, the conversation is discussing the necessary volume of pressure vessel and number of bottles needed to bring adequate compressed air for a round-the-world hot-air balloon trip with a crew of three. Using Boyle's law and given values for pressure and altitude, the necessary volume of pressure vessel and number of bottles can be calculated.
GatorAbe
Given that 1,206,900 liters of oxygen are required for a round-the-world trip for a hot-air balloon with a crew of three, and given that carbon-fiber wrapped bottles have a maximum pressure of approx 4500 psi, what total volume of pressure vessel would be necessary to bring along adequate compressed air for the flight? If the bottles come in volumes of 12ft^3, how many bottles does this represent? The balloon flies at an altitude of 40,000 feet. Find these values for 40,000 ft and 0 ft (sea level.)
This question comes across as a standard Chemistry conversion. Air weighs 1.3 grams per liter. 1 psi is equal to .0703 Kg/cm, so 4500 psi equals 316.38 kg/cm.
The question seems to be asking me to convert liters to psi, but I can't figure out how to do that, even when I try converting liter to kg/cm.
Use Boyle's law. P1V1 = P2V2
For P1 use 1 atm (what is that in psi?). You know V1 and P2 as well. Can you derive V2?
I would approach this problem by first converting all units to a standard measurement. In this case, it would be helpful to convert liters to cubic feet, as that is the unit given for the carbon-fiber wrapped bottles. To do this, we can use the conversion factor of 1 liter = 0.0353 cubic feet.
So, 1,206,900 liters of oxygen would be equal to 42,658.9 cubic feet.
Next, we can use the given information about the maximum pressure of the bottles (4500 psi) to calculate the total volume of pressure vessel needed. Using the ideal gas law (PV=nRT), we can rearrange the equation to solve for volume (V).
V = nRT/P
Where:
V = volume (in liters)
n = number of moles
R = gas constant (0.0821 L atm/mol K)
T = temperature (in Kelvin)
P = pressure (in atm)
Since we know the pressure (4500 psi) and the temperature (40,000 feet and sea level), we can calculate the volume of pressure vessel needed at each altitude.
For 40,000 feet:
P = 4500 psi = 310.26 atm (using the conversion factor of 1 atm = 14.7 psi)
T = 216.7 K (using the conversion factor of 1 K = -273.15 degrees Celsius)
V = (n)(0.0821 L atm/mol K)(216.7 K)/(310.26 atm)
V = 0.0578n
For 0 feet (sea level):
T = 288.2 K (assuming an average sea level temperature of 15 degrees Celsius)
V = (n)(0.0821 L atm/mol K)(288.2 K)/(310.26 atm)
V = 0.0765n
Now, to calculate the number of bottles needed at each altitude, we can divide the total volume of pressure vessel needed by the volume of each bottle (12 ft^3 = 339.8 L).
For 40,000 feet:
Number of bottles = 0.0578n/339.8 L
Number of bottles = 0.00017n
Related to Chemistry: Hot-Air Ballon Oxygen Storage
1. How does hot-air balloon oxygen storage work?
In hot-air balloon oxygen storage, pure oxygen is used to fuel the balloon's burner, which heats the air inside the balloon. As this air becomes less dense, it causes the balloon to rise. The oxygen is stored in tanks on the balloon or in a separate vehicle that follows the balloon.
2. Is hot-air balloon oxygen storage safe?
Yes, hot-air balloon oxygen storage is generally considered safe. The tanks are made of strong materials and are designed to withstand the pressure of the compressed oxygen. However, it is important to follow safety protocols and regularly check and maintain the tanks to ensure safe operation.
3. How much oxygen is needed for a hot-air balloon?
The amount of oxygen needed for a hot-air balloon varies depending on the size of the balloon and the duration of the flight. On average, a 90-minute flight requires around 50-60 liters of oxygen. Pilots often carry extra oxygen in case of emergency or unexpected changes in weather conditions.
4. Can any type of oxygen be used for hot-air balloon storage?
No, only medical-grade oxygen should be used for hot-air balloon storage. This type of oxygen is purified and free from contaminants, making it safe for human consumption. It is important to use the correct type of oxygen to ensure the safety of passengers and the successful operation of the balloon.
5. How is the oxygen refilled in hot-air balloon storage tanks?
Oxygen tanks used for hot-air balloon storage can be refilled at a local oxygen supply company. The tanks are connected to a compressor that fills them with pure oxygen. It is important to follow proper safety protocols when refilling the tanks to prevent accidents or contamination of the oxygen.
  • Mechanical Engineering
