Chemistry-potassium permanganate lab
  • Thread starter jessica.so
  • Tags
    Lab
In summary, titrations using permanganate are performed in acid solution because the reduction of permanganate to colorless Mn2+ is more favorable in acidic conditions than in basic conditions. Additionally, in neutral solutions, only one electron is transferred, resulting in a less precise endpoint for titration. Furthermore, the presence of a brown precipitate from the formation of MnO2 can interfere with the titration process. Therefore, if a bottle of potassium permanganate used for titrations has brown stains on the inside, it cannot be used for further quantitative experiments.
jessica.so
Q1: Why are titrations using permanganate performed in acid solution?
Q2: A bottle containing a standard solution of potassium permanganateis found to have brown stains on the inside. Why will this potassium permanganate be of no further use for quantitative experiments?
KNOWN:
Potassium Permanganate = KMnO4
It is known that potassium permanganate is a common lab oxidizing agent [it reduces]. It naturally has an intense purple color but when potassium permanganate is reduced all the way to Mn2+, it becomes colourless. A solution is titrated when a faint purple colour remains.
1/2 Reactions:
The reduction of permanganate:
In acid: MnO4- + 8H+ + 5e- ==> Mn2+ + 4H2O
In neutral solution: MnO4- + 4H+ + 3e- ==> Mn2+ + 2H2O
In base: MnO4- + e- ==> MnO42+
Interesting that you indicate these:
1/2 Reactions:
See that those show the oxidizing power seems higher in acid conditions than in basic conditions. This might indicate a quantitative advantage but I'm not really sure how to justify this (maybe someone familiar with the nernst equation knows how). The manganese ion probably does not sit in solution just as the ion but may form an oxide brown precipitate; which condition necessary, not sure.
... also, jessica.so, you should use either more careful text use or apply the proper tag to express certain information.
MnO42+ is NOT what you mean. You mean MnO4+2 (that is if we can stick two tagged expressions together). (but somehow, that can not be what you meant, either. How do you reduce an ion and have a result with a higher positive charge?).
Related to Chemistry-potassium permanganate lab
1. What is potassium permanganate and what is it used for?
Potassium permanganate is a chemical compound with the formula KMnO4. It is commonly used as a disinfectant, oxidizing agent, and water treatment chemical. In the lab, it is often used as a reagent to determine the presence of certain substances, such as organic compounds.
2. How is potassium permanganate used in a lab setting?
In a lab, potassium permanganate can be used as a titrant in redox titrations, to oxidize alcohols, and to analyze the amount of iron in a sample. It can also be used to create a purple stain for microscopy and to test for the presence of unsaturated bonds in organic compounds.
3. What safety precautions should be taken when working with potassium permanganate?
Potassium permanganate is a strong oxidizing agent and can cause irritation to the skin and eyes. It should be handled with gloves and safety glasses, and any spills should be cleaned up immediately. It is also important to keep it away from flammable materials and to never mix it with acids.
4. How is potassium permanganate prepared for use in the lab?
Potassium permanganate can be prepared by dissolving the solid crystals in water. The resulting solution has a deep purple color. It is important to use the appropriate amount of KMnO4 to achieve the desired concentration for the specific experiment.
5. What are some common reactions involving potassium permanganate?
Potassium permanganate is commonly used in redox reactions, where it acts as an oxidizing agent. It can react with alcohols to produce carboxylic acids, and with alkenes to form diols. It can also react with organic compounds containing double or triple bonds to form products with lower oxidation states.
21K
16K
10K
9K
