Chemistry Problem- Burning Magnesium
In summary, the product resulted from burning magnesium is magnesium oxide (MgO). The lab procedure involves heating a crucible, measuring the length and mass of the magnesium ribbon, breaking it into small pieces and heating it for 7-10 minutes. The resulting product is then cooled and distilled water is added before heating it again. The purpose of adding water is to remove any impurities and the cover on the crucible helps prevent nitrogen from reacting with the magnesium. However, the accuracy of the measurements and equipment used may affect the results. In this case, the amount of oxygen in the MgO was negative, possibly due to smoke being produced during the burning process. The composition of this smoke is unknown.
rasperas
Short Question- What is the product resulted from burning magnesium?
More Detail- For a chemistry lab I had to react magnesium oxygen- and thereby find out the empirical formula. Below is the lab procedure and my work.
Procedure-
1) Heat a clean dry crucible to redness. (to prevent extraneous r/x's)
2) Allow crucible to cool and mass and record.
3) Cut a piece of Mg ribbon about 5 cm. long.
4) Measure the length of Mg and record (+_ .0001 m) mass 1.00m MG = 1.2819
5) Break the Mg ribbon into small pieces into the bottom of the crucible.
6) Set crucible on ring stand/ clay triangle.
7) Heat 7-10 minutes.
8) Check for and unreacted Mg.
9) Allow crucible contents to cool.
10) Add just enough distilled water to cover the contents in the crucible.
11) Gently heat the crucible again to dry the product.
Data
a. Mass crucible 19.29
b. length Mg .0461 M (46.1 mm)
c. mass crucible and product 19.41 g.
Analysis
Mass Mg 1.2819 x .0491 = .0591
Mass O 19.41-19.29-.0591
Mole Mg .0591 g / 24.305 = .00243 mol Mg
Mole O .06 g / 15.999 = .004 mol O
Mol Ratio .004/.00243 = 1.6 mol 0 per 1 mol Mg x 2 (b/c empirical formulas contain integers only)
Allowing for room of error I get Mg2O3. However here's the rub. Mg= charge 2+
O = charge 2-. 2 x 2 = Total charge of 4+ on Mg. 2 x 3 = total charge of 6- on O. Unablanced.
Is this answer (Mg2O3) correct or is it wrong -(too many innacurate measurments in the data).?
Out of curiosity- What is the purpose of adding distilled water and then evaporating it? The cover to the crucible was on most of the lab- but never-the-less, is this sufficient to prevent nitrogen from skewing the results by reacting with Mg?
Thanks,
Rod Aspera
Magnesium oxyde.[itex] MgO [/itex]
Procedure-
Data
b. length Mg .0461 m (46.1 mm)
Analysis
Thanks,
Rod Aspera
Check your numbers,again.Give units in SI:m,Kg,s.What is the linear density of Mg??Give the figure in Kgm^{-1}.
There's no such thing as
[tex] Mg_{2}O_{3} [/tex]
The mole ratio should be
2moles of Mg+1mole 0_{2}=2moles MgO.
One mole of oxigen has 32g=0.032Kg,not 16g=0.016Kg
Daniel.
For personal simplicity, I was just expressing oxygen as non-diatomic; everything in the problem was adjusted to allow this.
Thankyou for the help.
After thinking about the problem, I realized it is an issue of accuracy. The rulers provided by school are standard "walmart" rulers. The scales also aren't scientific quality.
For "personal simplicity" means entering conflict with science.One mole of Oxigen has N_{A} molecules and that's exactly 32g,not 16g.Oxigen is diatomic,and in chemical reactions it will always enter as a diatomic molecule;only under exceptional conditions it appears monoatomic,e.g.the redox reactions involving [itex] H_{2}SO_{4},H_{2}O_{2},HNO_{3},H_{2}SO_{5} [/itex] and so on.but in this case,it is a product of reaction,not a reactant.
Daniel.
Daniel.
My question is alwo related to Mg burning. We did the experiment at school & after MgO was produced, we massed it. It turned out that the amount of oxygen in MgO was negative--MgO weighed less than the Mg I started out with.
I'm assuming it's because smoke was given off. But why was smoke produced & what exactly is in that smoke?
Related to Chemistry Problem- Burning Magnesium
1. What happens when you burn magnesium?
When magnesium is burned, it reacts with oxygen in the air to produce magnesium oxide. This process also produces a bright white light and a lot of heat.
2. Why does magnesium burn with a bright white light?
The bright white light produced when magnesium burns is due to the high temperature of the reaction. At high temperatures, electrons in the magnesium atoms become excited and emit energy in the form of light.
3. What is the chemical equation for burning magnesium?
The chemical equation for burning magnesium is: 2Mg + O2 → 2MgO. This means that two atoms of magnesium react with one molecule of oxygen to form two molecules of magnesium oxide.
4. Is burning magnesium a physical or chemical change?
Burning magnesium is a chemical change. This is because the magnesium atoms are undergoing a chemical reaction with oxygen to form a new substance, magnesium oxide.
5. How does the burning of magnesium demonstrate the Law of Conservation of Mass?
The burning of magnesium demonstrates the Law of Conservation of Mass because the total mass of the reactants (magnesium and oxygen) is equal to the total mass of the products (magnesium oxide). This means that no atoms are gained or lost during the chemical reaction, only rearranged to form new substances.
16K
46K
