Chemistry projects that I can create at home
The discussion centers around finding safe and cost-effective chemistry project ideas for 12th-grade students without access to a laboratory. Suggestions include synthesizing potassium ferrioxalate to create green crystals, which involves using diluted household chemicals. However, caution is advised, and it's recommended to have supervision from someone experienced. Another idea is to grow sugar crystals by dissolving granulated sugar in warm water and suspending a string in the solution, allowing crystals to form as the solution cools and evaporates. Variations could include adding colorants to different solutions. A simple titration experiment using vinegar and baking soda is also suggested, emphasizing the importance of understanding chemical reactions and safety precautions. Participants highlight the necessity of using protective gear, such as goggles, before conducting any experiments.
Saba_467
TL;DR Summary
Mini Chemistry projects to work on
There is no laboratory in my school ,looking for best chemistry project ideas for the 12th class students at minimal cost and that can be prepared at home .
need suggestions on this,response would be appreciated
Chemistry news on Phys.org
I have a synthesis manual for potassium ferrioxalate lying around which is actually quite simple and the "dangerous chemicals" are diluted. Makes some really nice green crystals, and tends to be succesful.
All chemicals should be available as household chemicals.
Although, I'm not sure it's such a good idea unless you have someone experienced to look over your shoulder.
Some few people like to prepare soap at home, but still this requires care and handling of caustic potash and caustic soda. Use gloves, goggles, and arrange for plans in case of accidents.
There is always the grade school standby of growing sugar crystals.
  1. Dissolve granulated sugar in warm or hot water. You want a saturated solution.
  2. Mostly fill a clear glass container (drinking glass?) with the solution.
  3. Suspend a string in the solution (Cotton, Linen, etc. Not Synthetic). To keep the string away from the sides, tie one end to a safety pin, hair pin, or whatever can be found around the house. The other end is held with a stick (or whatever is handy) across the top of the glass.
  4. As the solution cools and evaporates, sugar crystals will grow on the string.
I don't remember the fine details or how long it takes, better try it first to get everything right!
A variation could be adding various colorants to multiple copies of the experiment and periodically moving growing crystals to different solutions.
You could also vary the solution depth in the different colors, showing how colors combine.
Have Fun!
Tom
It's not flashy, no crystals or explosions, etc., but I would suggest a simple titration experiment. Vinegar has acetic acid in it; but how much? You'll need to get an appropriate indicator, like litmus paper. But then you can measure everything carefully and add baking soda to balance the pH. This is the sort of real chemistry that people do. It's mostly about understanding the reactions, designing the experiment, executing it properly, and calculating an answer.
Extra credit - How much CO2 was produced when you did the experiment?
Likes Saba_467
I will try it once thank you so much for the suggesting me
yeah good idea, however I don't have googles right now to prevent from accidents
Then don't do any chemistry experiments until you can get a pair.
  • Haha
Likes chemisttree, DrJohn and symbolipoint
