Chemistry - stoichiometry, solutions
In summary, the question asks for the mass of precipitated silver bromate when 0.800 g of silver nitrate and 0.473 g of potassium bromate are added to 238 mL of water. The limiting reactant is potassium bromate, and using the molar masses of the reactants and product, the mass of precipitated silver bromate is calculated to be 0.667 g. Water is not included in the calculation as it does not participate in the reaction.
excel000
0.800 g of silver nitrate and 0.473 g of potassium bromate are added to 238 mL water. Solid silver bromate is formed, dried, and weighed. What is the mass, in g, of the precipitated silver bromate? (Be careful to enter the correct number of significant figures. Do not enter units.) Assume silver bromate is completely insoluble.
AgNO3 + KBrO3 -> AgBrO3(s) + KNO3
0.800gAgNO3/169.66gmol-1AgNO3 = 4.7x10^-3mol
0.473gKBrO3/166.998gmol-1KBrO3 = 2.83x10^-3mol <---- Limiting Reactant
2.83x10^-3molAgBrO3 x 235.77gmol-1
= 0.667g AgBrO3
that was my attempt, but i completely ignored the water part since I don't really know what that is for, so I'm pretty sure I'm wrong. any help on this would be greatly appreciated
Your approach to solving this problem is correct. However, you should also consider the water in the reaction. Since the water is the solvent, it will not participate in the reaction and will not affect the amount of product formed. Therefore, you can still use the given amounts of silver nitrate and potassium bromate to calculate the mass of the precipitated silver bromate, as you have done. However, to determine the final mass of the silver bromate, you should subtract the mass of water used from the calculated mass. This will give you the mass of the silver bromate precipitate alone. Remember to use the appropriate number of significant figures in your final answer. Good job on considering the limiting reactant and using the correct molar masses in your calculations. Keep up the good work!
Related to Chemistry - stoichiometry, solutions
1. What is stoichiometry in chemistry?
Stoichiometry is the branch of chemistry that deals with the quantitative relationship between reactants and products in a chemical reaction. It involves using balanced chemical equations to determine the amount of products that can be formed from a given amount of reactants.
2. How do you calculate the molarity of a solution?
Molarity is calculated by dividing the moles of solute by the volume of the solution in liters. This can be represented by the formula M = moles of solute / volume of solution (in L).
3. What is the difference between a solute and a solvent?
A solute is a substance that is dissolved in a solvent to form a solution. The solvent is the substance that dissolves the solute and is typically present in a larger amount than the solute. For example, in a saltwater solution, salt is the solute and water is the solvent.
4. How do you calculate the concentration of a solution in parts per million (ppm)?
To calculate the concentration of a solution in ppm, divide the mass of the solute (in grams) by the mass of the solution (in grams) and multiply by 1 million. This can be represented by the formula ppm = (mass of solute / mass of solution) x 1,000,000.
5. What is the difference between a dilute and concentrated solution?
A dilute solution has a low concentration of solute compared to the amount of solvent, while a concentrated solution has a high concentration of solute. This can be determined by calculating the molarity of the solution. A higher molarity indicates a more concentrated solution, while a lower molarity indicates a more dilute solution.
