Chi-square test: why does it follow a Chi-square distribution
In summary, the Chi-square test between observed and expected distributions can be interpreted as a test based on the second order Taylor approximation of the Kullback-Leibler divergence. However, in order to use this approximation for decision testing, the assumption is made that the error terms in the equation follow a normal distribution. This assumption is based on the fact that if X is a binomial random variable, its distribution can be approximated by a N(0,1) distribution. This assumption also implies that the data in the contingency table follows a multinomial distribution. Without this assumption, the calculated \chi^2 value may not follow a chi2-distribution.
mnb96
715
Hello,
it is well-known that the Chi-square test between an observed distribution O and an expected distribution E can be interpreted as a test based on (twice) the second order Taylor approximation of the Kullback-Leibler divergence, i.e.: [tex]2\,\mathcal{D}_{KL}(O \| E) \approx \sum_i \frac{(O_i-E_i)^2}{E_i} = \chi^2[/tex]
where i is the bin of the histogram (or contigency table). A proof is given here (page 5).
The question is: how do we know that each of the error terms [itex]\frac{(O_i-E_i)^2}{E_i}[/itex] on the right side of the above equation follows a normal distribution N(0,1)? There is probably some some assumption to be made...?
[itex] \frac{ (O_i - E_i)^2}{E_i} [/itex] is nonnegative, so it doesn't follow a normal distribution.
If [itex] X [/itex] is a binomial random variable representing the number of "successes" n independent trials with probability of success [itex] p [/itex] on each trial then the distribution of [itex]Y = \frac {X-np}{\sqrt{np(1-p)}
} [/itex] can be approximated by a [itex] N(0,1) [/itex] distribution.
Likes 1 person
Stephen Tashi said:
[itex] [/itex]
If [itex] X [/itex] is a binomial random variable ...
I see. There it is our assumption!
It seems to me that such an assumption automatically implies that the data in the cells of the contingency table are assumed to follow a multinomial distribution.
So in the end, although the formula for calculating the [itex]\chi^2[/itex] value is just an approximation of the Kullback-Leibler divergence, if we are willing to perform a decision test we still need the assumption that we are dealing with a multinomial distribution, otherwise the [itex]\chi^2[/itex] value that we calculated according to the formula above, does not necessarily follow a chi2-distribution.
Related to Chi-square test: why does it follow a Chi-square distribution
What is a Chi-square distribution?
A Chi-square distribution is a probability distribution that is used to analyze categorical data in scientific experiments. It is often used to test the independence of two categorical variables.
Why is the Chi-square test used?
The Chi-square test is used to determine if there is a significant relationship between two categorical variables. It helps scientists to understand whether or not the variables are independent of each other.
How does the Chi-square test work?
The Chi-square test works by comparing the observed frequencies of different categories to the expected frequencies. The resulting Chi-square value is then compared to a critical value to determine if there is a significant relationship between the variables.
Why does the Chi-square test follow a Chi-square distribution?
The Chi-square test follows a Chi-square distribution because the test statistic, which is calculated using the Chi-square formula, has a distribution that closely approximates the Chi-square distribution. This allows scientists to use critical values from the Chi-square distribution to determine the significance of their results.
What are the assumptions for using the Chi-square test?
The main assumptions for using the Chi-square test include having independent samples, having a large enough sample size, and having expected frequencies of at least 5 in each category. It is also important to ensure that the data is not skewed or biased in any way.
