thomassims
- 1
- 1
Has anybody ever seen Chinese Characters appear in a single record within a database table? I look forward to any suggestions.
Do you mean Chinese characters are showing up erroneously? If so, a Google search pulls up several cases of this when grouping by memo fields:thomassims said:Has anybody ever seen Chinese Characters appear in a single record within a database table? I look forward to any suggestions.
Chinese characters are logograms used in the writing of Chinese and some other Asian languages. They represent words or phrases rather than sounds, and are composed of strokes and radicals that give clues to their meaning.
Chinese characters may appear in MS Access if the software is set to support Chinese language input or if data from a Chinese language system has been imported. This allows for the use of Chinese characters in data entry and storage.
To input Chinese characters in MS Access, you will need to have a Chinese language enabled keyboard or input method installed on your computer. You can then switch to this input method while using MS Access to type in Chinese characters.
Yes, you can search for Chinese characters in MS Access by using the correct input method and typing in the characters you are looking for. You can also use the "Find" function to search for specific characters within a larger dataset.
In order to display Chinese characters properly in MS Access, you will need to have the correct language pack installed on your computer. This will ensure that the characters are rendered correctly on the screen and in any reports or forms within MS Access.
