MHB Choosing a ball at random from a randomly selected box
  • Thread starter Thread starter Sapphireluna
    Ball Box Random
The probability question involves selecting a ball from one of two boxes, each containing different numbers of white and black balls. The correct approach is to calculate the probability of choosing a box and then the probability of drawing a white ball from that box. The solution is found by determining the probabilities for each box separately and combining them, resulting in a probability of 7/12 for drawing a white ball. The initial confusion stemmed from treating the balls as if they were in a single box without considering the equal chance of selecting either box. Understanding the independent probabilities of each box is crucial for solving this problem accurately.
Sapphireluna
I got this probability question as homework, but I got very confused as I didn't know if I should calculate the balls in the 2 boxes as whole or if I should calculate the probability of the first box then add the probability of the second. Any help is appreciated.
Thanks.Here is the question:
There are 2 boxes, box A contains 20 white balls and 20 black balls, box B contains 10 white balls and 5 black balls. A box is chosen at random then a ball is taken at random from the chosen box, what is the probability that the ball is white?
First I thought, it should be the probability of box A + the probability of box B;
20/40 + 10/15 = 7/6
but then I thought it doesn't really make sense to me as this tells that I will always get a white ball?!
So I thought, I could do the probability of the whole lot;
30/55 = 6/11
this answer seems more reasonable, but then I was confused, as there are 2 boxes, so that the chances of a white ball being taken out of each ball should be different?
Mathematics news on Phys.org
Re: Help needed in this simple probability problem
Hello and welcome to MHB, Sapphireluna! (Wave)
I can see being tempted to approach the problem as if all the balls are in one big box:
$$P(\text{white})=\frac{30}{55}=\frac{6}{11}$$
However, we should approach it as follows:
$$P(\text{white})=P(\text{box 1 AND white})\,\text{OR}\,P(\text{box 2 AND white})=\frac{1}{2}\cdot\frac{20}{40}+\frac{1}{2}\cdot\frac{10}{15}=\frac{1}{4}+\frac{1}{3}=\frac{7}{12}$$
You were on the right track with your first approach, however you didn't account for the fact that we have only a 50% probability of choosing either box.
Thank you very much!
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
