Choosing the limits of integration
In summary, if you are given three limits of integration and are asked to find the volume of a solid between those limits, you should first do the z integral. Then do the x and y integrals to get two more limits.
Maxwell
513
If I'm asked to find the volume of a solid that lies below the surface z = f(x,y), and above to region in the xy-plane bounded by a certain curve...and I'm only given 3 limits of integration, what do I do?
For example:
z = 9 - x - y
Given y = 0, x = 3, y = (2x)/3
At first I thought I could get another limit for my x integral by solving y = (2x)/3 for x -- however, I then end up with an answer that has an x or a y in it. So I figure this must be wrong.
I then chose the limits for my x integral to be 0 and 3, (I choose 0 randomly) and I got an answer of 18. The books answer was 19. So I believe I am close.
Is that how I find the last limit if I am only given 3?
Thank you!
You should draw a picture of your region. The outer integral you set up has to have constant limits, and the inside integral will go between two functions that you can see from the picture.
For example:
z = 9 - x - y
I am not following here. Can you double check that there is no typo here. Did you mean *z=0* on the second line?
EDIT: I see that the question states that the volume is between the xy plane and the z function so the lower limit of z is 0. Fine. But the limits on x and y are still not clear. There should be two limits on x, it does not make sense to simply give one value of x. So there must be a typo.
Pat
The given curves (lines if you prefer) in the xy plane y = 0, x = 3, y = (2x)/3, define the bounded region (the wording of the problem is confusing as stated).
Maxwell, plot these three lines as suggested above if you haven't already. What do your limits of integration look like? For practice you should set up the integral as dxdy and also dydx (that is change the order of integration and set up the limits).
Oh! yes, of course (slapping myself hard!):frown: :frown:
That was obvious. Sorry for my dumb mistake. Thanks shmoe.
To Maxwell: Do the z integral first, from 0 (since it starts from the xy plane) up to the function given for z.
Now, do the x and y integral. As Shmoe suggested, it would be a good practice to do it two ways: x and then y or y and then x.
let's say you do y and then x. The way to think about it is the following. Since you integrate y first and then x, you must imagine having x fixed to some value as you vary y. Then the question is: for an arbitrary value of x within your region, the value of y varies from what to what? (hint: the lower limit is a number but the upper limit is a function of x)
Patrick
(S_0_3)(S_0_2x/3)(S_0_9-x-y)1 dzdydx
Performing first integration
(S_0_3)(S_0_2x/3) 9-x-y dydx
Performing Second Integration
(S_0_3) 6x-(2x^2)/3 - (2x^2)/9 dx
Performing Third Integration
3x^2-(2x^3)/9-(4x^3)/54 | plugging 3 in for all x values gives you a final value of 19.
Michael, we ask that people don't post full solutions. The goal is to help the original poster to work out the problem by himself/herself. The goal is to help him/her *learn*.
regards
Patrick
waaa, stop whining at me for u being lazy
FAQ: Choosing the limits of integration
What is the purpose of choosing the limits of integration?
The limits of integration determine the range of values for which a mathematical function will be integrated. This allows for a specific area or volume to be calculated.
How do I choose the appropriate limits of integration for a given problem?
The limits of integration should be chosen based on the boundaries of the region being integrated. This can be determined by understanding the problem and graphing the function.
What happens if the limits of integration are incorrectly chosen?
If the limits of integration are incorrectly chosen, it can lead to an inaccurate solution. It is important to double check the chosen limits to ensure they accurately represent the desired area or volume.
Are there any rules or guidelines for choosing the limits of integration?
Yes, there are some general rules to follow when choosing the limits of integration. The limits should be in the same order as the variables in the integrand, and they should not overlap or have any gaps in between.
Can the limits of integration ever be negative or complex numbers?
Yes, the limits of integration can be negative or complex numbers, as long as they accurately represent the boundaries of the region being integrated. However, it is more common for the limits to be positive real numbers.
